Panasonic KX-T7630 Corded Phone Logo
Anonymous Posted on Sep 10, 2007
System Directory Call Customer Service 1-8O5-465-751O To Fix Issue
I'm having trouble entering phone numbers to the system directory so all users can access the speed dials. I can enter numbers into the personal directory just fine, but can't for the life of me work out how to put numbers into the system directory.
  • 5 more comments
  • ALTech Feb 13, 2008
    I followed the steps given but found that numbers were added to the personal rather than system directory.
    Any advice on how else to do it or what i might be doing wrong would be appreciated.
  • ricci-sue Apr 03, 2008
    I have a copy of the operating instructions but it doesnt give clear instructions on how to enter speed dial numbers on the system directory can you help
  • dkcanuck Apr 10, 2008
    The solution described works for the personal directory but I want to save them in the system directory
  • Anonymous Nov 19, 2008
    Very ordinary manual - not at all helpful.
    I have tried several times to store names/extensions in the 'system' directory, but no instructions I can find on the net work!!!!
  • lmarvel Dec 17, 2008
    I want to program numbers so that when the person is calling their name comes up. How do I do this? Also, how can I change the names already associated with numbers in the phone?
  • sarymahal_01 Dec 23, 2008
    I have the same Problem. System Directory problem.... your solution is not helpful.. no one can help us...either technical support or customer service...
  • Patrik Parker Aug 26, 2019
    contact support
Anonymous
Level 2:
Sergeant:
  • Expert 274 Answers
  • Posted on Sep 15, 2007
Anonymous
Expert
Level 2:
Sergeant:
Answers
274
Questions
0
Helped
328908
Points
573
I assume you have the manual. I found it very difficult to follow, very poor. While "on hook" enter the number you want to call. Press "store" or "enter". Enter the name referring to the graphics chart on pages 7 & 8. It is set up for Alpha characters and it depends on which software is installed on your phone. Example: If you want the letter "A" you press the number 2 one time. If you want the number "2", you have press "2" seven times to display the number 2. Use the toggle key to move to the next letter or number you want to enter. When you have finished press "Store". It may take awhile but that's how its done. Not a very good system for the average consumer in my opinion. But that's how its done. I was unable to upload the manual. Here's the link if you don't have it: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Hybrid-IP-PBX-Phones/model.KX-T7630
When adding long distance numbers to the directory do I precede the #'S with a 1, or just enter the area code?
It will dial whatever you have entered --- if a 1 is needed
at the keypad, a 1 is needed to be stored in the directory
listing of the number.
I use the "10-10-987" service and have entered those
numbers into the directory entries, 'works fine.
1helpful
Panasonic KX TG2770 phone system I'm trying to store a voice mail access number given to me by my phone company, but I cannot find any way to get it entered into this phone. I would think this phone...
Try adding your voice mail access number into the directory of the KX TG2770. You will need to enter the number separately for the base and the handset or copy it from the base to the handset. On the base, press Conf/Edit. Then navigate (up/down arrows) to Save Directory. Once in this submenu, you'll be able to add a name and phone number.
Then to call the access number, go to the directory list and locate the name/number and call it.
Panasonic has the manual for your phone here: http://service.us.panasonic.com/OPERMANPDF/KXTG2770S.PDF . See page 33 and the following pages.
I hope this helps.
(Other phones have a voice mail waiting icon and let you program that number outside of the directory. These also check if you have voice mail waiting for the line that they are connected to. This phone doesn't seem to have that ability.)
How do I edit a phone number in the system directory? Regards John
The system directory sits in system program 001. It's access from the control phone, usually the first one in the system (101) and from there you press PROG **1234 and dial 001 ENTER If you keep pressing ENTER it will step through the numbers from 001 to 999, or between the first and second ENTER you can dial a 3-digit number. EXIT a few times or pick up the handset and drop it back down exits programming.
Carl
Can you retreive the last number of a person calling you
Using the Call Log or Directories
You can make a call with the call log or directories as follows:
Outgoing Call Log
Incoming Call Log
Extension Number Directory
System Speed Dialing Directory
Personal Speed Dialing Directory
Calling with a call log or directory
While on-hook
>Press Left or Right
until desired log/
directory appears.
>Press ENTER.
>Press Up or Down until
desired item appears.
>Off-hook
To cancel or exit, press cancel or exit.
Clearing the log information
>While confirming the log information
>Press "CLEAR".
Storing the caller's information for the Personal Speed Dialing Directory
>Press Up or
Down until
desired item
appears.
>Press STORE or
ENTER.
>Press STORE or
ENTER.
>Press "EXIT" or
PAUSE.
To enter characters, refer to "Entering Characters".
1helpful
Our office has Samsung KPDCS-12B LCD phones. How to we store and delete numbers please ?
to program the directory on a 12 button handse;
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
Your next command will be the MMC required.
To program the system speed dial directory
Enter 705 - Speed dial 12th Button down to toggle between
Enter 706 - Speed Name the 2 MMC
1helpful
Having trouble entering speed dials - please help!
Not knowing the specific model of the phone system itself (the PBX cabinet in the telephone closet) I would guess you are using the "personal directory" and it only has 10 number memory and it goes from 0-9. The system directory will give you more mems.
3helpful
Revising extension directory on LCD
Correct. Changes are done in system programming. In a TDA it resides in system program 004. You get there by going to the main phone or phone used to program, dial PROG **1234 004 and enter the extension number of the name you want to change. It will display the present name and let you use the keypad to spell out new names. For example 2 gives you ABCabc2. The right arrow steps to the next character and ENTER saves it.
Carl
1helpful
Changing numbers? Call Customer Service 1-8O5-465-751O To Fix Issue
To program the personal directory Its diferent to program the system directory. the personal has 8 number capaciti and the system has 999 number. To program the System directory
1.- Enter to PBX program mode from your station 101
2.- Choose program 001 to enter the quick dial numbers
3.- Choose program 002 to enter (Or change ) the Labels
1helpful
ROOT
Root Folder/ Directory refers to the main Folder which contains all the important informations and commands your player has. It is similar to your Root Directory in your PC -- Drive C:/ where all the system files are located.
Root Directory includes sub folders such as your player's Master Boot Record (MBR - very crucial, this is the boot operating system), music file directory, audio record directory, data files directory such as organizer and phone directory (if your player has one).
Root Directory is very important for your player's performance as it contains all the valuable informations and commands so your player would run under normal condition. Once everything was erased in that root folder, you'll render your player useless. So be extra careful when you upgrade your player's firmware as this erases all files including those the OPERATING SYSTEM in the root folder.
It is safe however to format within your player as this erases only your data files and music. Just to be sure, avoid formating your player in your PC's MY COMPUTER/ WINDOWS EXPLORER unless it is specified in the users manual.
Luckily, MBR are usually erased when you entered your player's SERVICE MODE and you choose to erase the Firmware using some special keys. So, as long as you're using your player as mentioned in your users manual, you're okay with it. If you doesn't know all about mp3 player repairs or upgrades, leave the SERVICE MODE or PLAYER RECOVERY to the technicians.
MANNY DE GUZMAN, JR.
aka "TECH DATA"
SoundMagik Home Studio
Manila, Philippines
Visit my website: http://mannydeguzmanartist.wetpaint.com
My talents/ modeling site: http//teenmodels2007.wetpaint.com/
My YouTube Channel "mannydeguzmanjartist":
http://www.youtube.com/user/mannydeguzmanjartist
My imeem.com social media channel "mannydeguzmanartist", where all my music editing, remixes, creations, and voice demos can be found: http://mannydeguzmanartist.imeem.com/
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
