Dell A920 InkJet Printer Logo
Anonymous Posted on Aug 28, 2013
My Dell A920 Inkjet Printer will not recognize my color cartridge which is brand new?
Geoffrey White
Level 3:
  • Master 3,965 Answers
  • Posted on Aug 29, 2013
Geoffrey White
Master
Level 3:
Answers
3965
Questions
Helped
913753
Points
10651
Is it a Dell cartridge or a generic cartridge? No-name cartridges sometimes lack the chip which the printer looks for. Return the cartridge for an exchange.
Testimonial: "I bought it from Dell. So yes."
5 Related Answers
Anonymous
  • 624 Answers
  • Posted on Dec 29, 2006
SOURCE: DELL A920 INKJET PRINTER
The flashing LED is the diagnostic. Note the pattern then go to this web page and follow the instructions. http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&journalid=44B30B75976F11DBB4225D60633A6D93&l=en&s=gen&treeid=C85EECBE141F49CD9F3D7DE39329713B Let us know the outcome or if you have any other questions.
Anonymous
  • Posted on Feb 28, 2007
SOURCE: Dell 962
Just found this partial fix: "Try removing the color cartridge and try printing with the color cartridge out. If it gives you a message that the cartridge is missing, it will still allow you to print by clicking "continue". And from there, it will allow you to print black. I think it really is a problem with your color cartridge." From searching the net, this seems to be a major problem with no solution from Dell!
Anonymous
  • 24 Answers
  • Posted on Oct 24, 2007
SOURCE: my dell a940 all in one printer no longer prints in color
Sometimes this happens with most printers i advice that you get hold of this software..called Virtual Printer it takes care of many of the printer problems...It wil really save you lot of time and hair!Atleast  it woked for all of my 2 printers till now..
Anonymous
  • Posted on Oct 13, 2008
SOURCE: dell 922 does not recognize cartridge
Replaced B/W & color cartridges. Display indicates "color cartridge missing".
Anonymous
  • 8637 Answers
  • Posted on Jan 29, 2009
SOURCE: Color printer won't print color
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
My Dell A920 black Ink holder broken
call DELL technical support number and ask if there is available spare parts for broken cover replacement, you might end up replacing the whole ink carriage.
How can I clean my A920 Dell printer?
have it serviced by a dell technician if it badly needs cleaning, doing it on your own does more damage to printer.
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Installed new ink cartridges and the color works but the black does not
Perform a print head clean in printer software. OR if a tricolour cartridge most probably empty as its the most often used.
My Dell A920 printer will not print the color blue. I've replaced the ink, 2 times. Changed the quality of print to "Best" and still get only the reds & yellows... Any ideas?
hi there !
-try the old cartridge if it will print the correct colour; the problem is the cartridge; otherwise it is the printer.
cheers !
1helpful
Will not print in color
hi there,
try to access the dell all in one center. there's a link there that says maintenance. there's an option that says clean to fix horizontal streaks.
then try to print again.
if still same. try to remove the color ink. remove the power cable of the printer. using a clean cloth, wipe the contacts of the copper strip inside the color cartridge carrier where you put the color cartridge. also clean the copper strip of the color cartridge.
if still same. try to uninstall/reinstall the printer driver.
if still same. 3 points of failure
1. cartridge problem again. most probably bad cartridge batch 2. printer driver issue. 3. printer itself.
2answers
1helpful
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
A920 printer will not print in color & the cartridge is OK
is there any more colour ink inside? if there is ink inside you just have to open your printers properties dialog and look for a color option that uses black only. 2. see if the colors are blocked
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
