Trying to remove old belt from motor and pump assembly. Have removed the three torx screws but am unable to remove pump. I suspect there is a nut or something on the inside that is preventing it from coming off. The water pump on this washer is attached to the same shaft that the drive pulley is on. I have already gone as far as I dare in pulling and prying on the pump and hope I haven't destroyed it.
Remove the bottom kick plate. Remove 4 big bolts and unplug the motor. Move the motor assembly to a work bench. You need a T-20 torx driver to remove the pump screws and remember the rear pump leg goes between the belt. I have your Amana washer repair manual HERE
that belt replacement requires some effort but you can do it with a little patience. then you will have your reward plus your washer will be fixed. you'll need a torx head screw driver ( if u don't have one they sell them at the hardware store) and a 1/2 inch socket. it requires removing motor pump assembly from washer and then removing pump from motor. it will take you a while. it's not as hard as it looks. good luck.
I just did this today. You have to remove the motor. first start by removing the two hoses then remove the four 1/2 inch bolts that hold the motor/pump assembly. the wires are clippes to a bracket, pry that off removr the whole motor assemly with the bracket by pushing on the tub to manipulate it out. Then remove the three #25 torx screws that hold the pump to motor, remove the pump then route the belt onto the pulley around the inside pump mount put the motor back on the reinstall it the way you took it off. its not that bad (for the first time ever working on a wash machine). I hope you dont have the problem I do, the belt slips in the spin mode - that is probably why the belt failed in the first place I am still trying to find a solution to that. if you just have a failed belt, you will be just fine.
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
remove the 4 bolts holding motor to tub and frame remove wire harness from motor remove pump hoses turn assembly upside down 3 torx screws hold pump to motor note routing of old belt around idler pulley and pump studs reinstall in reverse
Steps for Replacing the Belt Tools needed: Nut driver or socket set. Torex screw driver. 1. Unplug the power cord from the electric socket and
remove the front panel. 2. Disconnect the power coupling from the motor. 3. Disconnect the 2 hoses from the pump.Be aware that the pump still contains
between 1 and 2 cups of water,
and it WILL all come out. 4. Remove the belt from the idler arm, pushing the
belt UNDER the idler arm.Yes, your hands will now be quite
greasy. 5. Remove the belt from the main transmission by
pushing the belt under the
transmission pulley. 6. Remove the 4 bolts that hold the motor assembly to
the washing machine body.Remove the motor assembly with belt
from the washing
machine. 7. Turn the motor upside-down.With the torex
screwdriver, remove the 3 bolts that hold
the pump to the motor.Remove the pump from the motor (in my case,
the motor shaft fit into a slot in
the pump; while it was snug, it was
not melted or rusted, and did
just come out). 8. Clean pump and motor as desired. 9. Install new belt and reverse the steps to
re-install.
No. The motor and pump assembly need to come off. There is 4 1/2 inch bolts that hold this assembly to the main mechanism. 2 on top and 2 on bottom. Work belt off bottom pulley on transmission and then remove these bolts. Turn motor over and remove 3 torx screws holding pump to motor. Install new belt then reinstall pump with 3 screws. Reinstall assemblt to mech. Pu top 2 screws in first then bottom 2. Be sure belt goes on left side of black plastic idler pulley. Work belt around transmission pulley. You can press on opposite end of idler pulley arm to loosen belt tension. Make sure belt is on all pulleys before testing.
Your question suggests you are trying to remove the pump pulley. This pulley is not removable. The motor pulley should have a set allen screw in it to release.
