Try these codes:
1004, 1006, 1008, 1019, 1062, 1068, 1069, 1075, 1076, 1077, 1088, 1116, 1130, 1132, 1134, 1161, 1183, 1189, 1196, 1353
These are the codes for Sylvania TVs.
Check this web page for instructions:
http://www.eliztech.com/remotes/rca-prog-v2.php
SOURCE: rca remote, codes don't work for sylvania tv
Trata con esto.
Presiona el boton Code search y mantanlo asi hasta que el led se quede encendido suelta y presiona el boton TV despues vas a presionar y soltar el boton Power hasta que el televisor se apague despues presionas el boton enter y el codigo queda almacenado.
El Tv tiene que encenderse primero manualmente.
SOURCE: philips universal remote - tv codes for Sylvania
Several people in the on-line forums suggested inputting the brand search codes for Philips and Magnavox sets -- but it didn't work for me. Someone else suggested that Funai Corp (China) now makes some Sylvania sets, and their rep said that universal remotes don't work for their products. My Philips Universal Remote says to enter "0" for the brand search code, and that will instruct it search for all the codes installed in it. But there are approximately 300, so be very patient. And it didn't work for me anyway. . . but maybe it will for you.
If you do find an answer/solution, pl post it, OK? Thanks.
Donna
SOURCE: i lost the remote to my sylvania model; 6419TE 19
Have you tried the search fuction,some of the remotes will search for a code that works.
SOURCE: Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
