SOURCE: Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
SOURCE: thermostat ?
I'm thinking the bi-metal is working, that's why you can hear a click, but the contacts are welded together. The bi-metal doesn't have enough strength to break the weld. Time for a new thermostat.
SOURCE: My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
SOURCE: frigidare window air conditioner with
The Energy Saver is not supposed to just shut down the unit, it cycles the unit on and off as room temperature alters.
Practically it put unit to rest when temperature is reached, and wake it up when temperature change again.
It is just a mode that turn the compressor earlier to save energy, but the compressor will still be working until temperature is reached.
