The mirror inside might be stuck in the up position. Take out the lens and look inside. Do you see a mirror positioned at 45 degrees? If not, it might be stuck in the up position at the view finder prism.
Which lens? Is this happening with just one lens, or with every lens you mount on the camera?
If you remove the lens and look through it, can you see light? Perhaps an upside-down view of whatever is on the other side?
If you look into the camera body after removing the lens, do you see a mirror at a 45-degree angle?
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
It's happening with every lens. I see a little bit of light if I remove the lens, but other than that, nothing.
