No additional drivers are necessary. Your Epson GT-15000 is listed in "Printer and Scanner software available for download,"http://support.apple.com/kb/HT3669 .
To add your scanner, simply plug it in. If it does not appear in Apple Menu > System Preferences > Print & Scan, you may need to run Software Update (also from the Apple Menu, second item down), and then click the plus ( + ) button in the lower-left of Print & Scan, select your scanner, and then add the printer.
The default scanning application in OS X is Image Capture. After completing the above steps, open Applications > Image Capture and you should see your scanner listed on the left.
SOURCE: HP Director buttons greyed out in Mac OS 10.5.4; scanner can't find IMac
Hi
Reinstall the software it will work..
For installation and scanner process u can refer the user manual.
Check this one
http://www.lavc.edu/IT/Manuals/Printer_HP_Laserjet_3380_User_Guide.pdf
SOURCE: scanner not working cannot find scanner WINDOWS XP
Cannot scan on IMac with Epson Stylus CX3900?
SOURCE: driver for epson dx8450. my computer is mac osx G5
my epsom dx8450 just says cannot recognize ink cartridge but it is a new cartridge
Hi greer200, to "get the Manual for the Epson GT-15000."
Go to this "Website link," below.
Select the [Manual] you need from the "List."
"Download the Manual !
For more information.
"View the FAQ -> Find: Scroll to find."
"Take a moment to rate the help."
Thanks paul7of9
Click here: http://www.epson.co.uk/Scanners/Epson-GT-15000/Drivers-Support?supportLandingPage=true
