The SteamClean option spot cleans the oven in 20 minutes and is recommended for cleaning light spills on the bottom of the oven cavity. When used routinely, the SteamClean option reduces the need for frequent self-clean cycle use. To use the SteamClean option, pour 12 ounces (1 1/2 cup) of water into the bottom of the oven cavity, close the oven door and push the SteamClean button. At the end of the cycle, consumers wipe out the bottom of the oven, easily removing oven soils. The steam cleaning option is eco-friendly and does not require frequent use of the self-clean cycle, which can create a strong odor. Read this in a post about the new whirlpool ranges
Suamaygiat trung tam bao hanh may giat electrolux chuyen sua may giat electrolux gia re .
SOURCE: Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
SOURCE: how to use self cleaning oven
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION!!!
SOURCE: Cleaning my self-clean oven
Turn the oven to "clean" and lock the door if the oven has a manual door lock. The oven may have an automatic timer for the clean setting. If it doesn't then you'll have to turn it off yourself in three or four hours. Don't be surprised if the oven puts out a very foul smell while it's cleaning itself as that's normal for an oven that hasn't been cleaned in so long. After it's done, wait for the oven to cool and then wipe out the ash from the inside of the oven.
SOURCE: 1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
