Intel D101GGC Motherboard Logo
Anonymous Posted on Aug 28, 2013
Voltage ic no vcore
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Intel Master 2,226 Answers
  • Posted on May 19, 2014
James Miller
Intel Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447516
Points
2985
Bad motherboard then also check power supply out
E1229 CPU2 vcore regulator failure on Dell R510
It means the voltage reg on the motherboard has failed or the monitor for it is failing. Typically, this is a warranty repair from Dell. If you're out of warranty, then you can either replace the mother board, or if you're brave, replace the regulator and all the broken caps that probably caused it to fail.
Issue modify vcore for e6300
Really?
Are we talking about the Asus P5LD2-VM motherboard, Zoltan?
(Zoltan is a C-o-o-o-o-l name!)
Because I'm looking at the motherboard manual right now, and state you are mistaken.
1) Use the Right Side Arrow key, and highlight the - Advanced - tab on top of the Main menu.
2) Use the Down Arrow key and highlight -
JumperFree Configuration
Press the Enter key.
Configure System Frequency/Voltage
AI Overclocking - [Auto]
Use the - key, (Minus), and move Auto to Manual
Use the appropriate arrow key, and highlight -
CPU VCore Voltage [ Auto ]
There are 40 Voltages you can choose from.
1.7000Volts to 1.2875Volts.
Remember,
Use SMALL increments at a time. Do a 24 hour stability test.
(Small increment example, 1.7000V to 1.6875V )
If your system is stable for 24 hours, then you can come back, and change the Voltage one more small increment.
(1.6875V to 1.6750V)
Also remember; you are changing the Front Side Bus of the Processor. (FSB)
Change it TOO much, and your ram memory, and expansion slots will not work.
(Ram Memory typically operates at a frequency rate ('Speed'), of half of the FSB of the Processor.
Processor FSB is 800MHz for example? Ram Memory operates at 400MegaHertz.
Intel Core2 Duo E6300? 1066MegaHertz Front Side Bus.
{1066MHz FSB}
Ram memory? 533MHz)
Asus Support > P5LD2-VM > Download page,
http://www.asus.com/Motherboards/Intel_Socket_775/P5LD2VM/#download
For the - Select OS box, click on the blue Down Arrow, and choose WinXP. (Doesn't matter as you are just going for the manual)
Click on the + sign next to Manual (14)
Scroll the inside scroll bar down until you come to -
Version E2281 -
P5LD2-VM User's Manual for English Edition (E2281)
Click on the blue - Global
A PDF file version of the motherboard manual will come up.
Using the PDF file page number box at the top, go to;
Page 63 - 2.4 Advanced menu
Page 65 - CPU VCore Voltage [Auto]
http://www.techwarelabs.com/reviews/processors/e6300/
Overclocking article at the end. Just one of the hundreds of overclocking articles out there.
Regards,
joecoolvette
Where is vcore set? bios or cpu driver?
Vcore settings can usually be found in the bios settings menu. But be careful when playing around with those settings!
Vcore voltage
check the cpu voltage to the board jim
BIOS voltage settings for ASUS M2N-SLI Deluxe 570 SLI chip set.
Hi glen909nwi,
Here's the configuration for that board. If your trying to overclock, you'll want to go with a higher setting.
CPUChiosei HT Voltace 11.20 VI
Allows you to set the pocessorhipset HyperTranspoit voltage.
Configuration options: [1 .20V] [1 .25VJ 11 .30V] [1 .35VJ [+1 .40V1 [+1 .45V] [+1 50V]
Chtoset Core Vo#aae f1.40V1
Allows you to set the dlipset core voltage.
Configuration options: [1 .40V1 [1 .50V] [1 .60V]
Ctitpset Slan&w Core Vo?taoe 11.40 VI
Allows you to set the diipset standby coe voltage.
Configuration options: [1 .40V] [1 .6OVJ
CIhVsef Fi-E Voitaae 11.50 VI
Allows you to set the dlipset PCI Express voltage.
Configuration options: [1 .50V1 [1 .55V1 [1 .60V] [1 .65V] [1 .70V1
CPU Vcore Offset Voltage fDisabdJ
Allows you to csable or set the processo vCore offset voltage.
Configuration options: [Disabled] [Offset lOO.OnIV]
ASUS M2N-SU Deluxe
What is the voltages , vcore etc for normal settings of a amd 4600+
Just got to into your Bios and reset the factory settings and It will reset the changes you may have made.
1helpful
Hardware monitor found an error
First I would make sure all the power plugs are properly plugged into the motherboard and all other devices.
If that does not solve it then I would get the Power supply tested at a local PC shop. Or just get a new decent power supply. Looks like the Power supply without a doubt is defective.
Hardware Monitor Problem Sony Vaio
have you tried installing a seperate controller card?
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
