Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
IF YOU GET A CODE 12 WHICH IS THE BLINK PAUSE BLINK BLINK THEN THE TV THINKS THERE IS NOTHING WRONG WITH ITSELF. ARE YOU SURE IT ISNT CODE 22 BLINK BLINK PAUSE BLINK BLINK? THAT WOULD BE A CONVERGENCE FAILURE COMMON FAILURE FOR CRT REAR PROJECTIONS.
found this tonight:
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards (SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area)
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board with IC8001 (Pesks Lite 2)
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
