SOURCE: non working keys on laptop
You should just need to replace the keyboard.
However finding a keyboard for a packard bell in the US can be hard. That brand hasnt been sold here in years.
If you are in europe it should be less of a problem though.
Made sure to get the exact model of the laptop to get the right keyboard.
SOURCE: Excel - Automatically update invoice numbers
Yes but You need to tell your exact requirements eg. from where you would like to update your Invoice Template i.e from A Separate Database or from a Dropdown List etc
SOURCE: cannot insert columns in excel
This error message occurs if the following conditions are true:
There are two ways to fix this problem.
Method 1:
Temporarily toggle the option from "Nothing (hide objects)" to All
In Excel 2007, temporarily toggle the option from Nothing (hide objects) to All, and then insert the rows or columns as needed. To do this, follow these steps:
Notes To use the keyboard shortcut to toggle this selection, press CTRL+6.
If these steps do not let you hide rows or columns or insert rows or columns in Excel 2007, try the steps in method 2.
Method 2:
Change the position property of the object to Move and size with cells
To work around this issue, Excel 2003, Excel 2002, and Excel 2000, change the position property of the object to Move and size with cells. To do this, follow these steps:
For more information, visit the Microsoft Knowledge Base article:
http://support.microsoft.com/kb/211769
SOURCE: non system disk or disk error
Hi
I am no expert but in your case you need to get or download 6 system disks on 6 floppy drives if you don't have another PC to download, give me your home address , and I will send you the 6 diskettes, when the sixt's disk is inserted you will read a note saying insert the CD windows XP this will guide you the rest of the way also you will need the product key, good luck
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
