I am using sony 4GB SD card 15MB/s. my SD card is write protected how it format
To remove write protection:
Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Double click the key WriteProtect in the right pane and set the value to 0
In the Data Value Box, press OK
Exit Registry, restart your computer and then re-connect your USB pen drive to your computer.
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
SOURCE: PNY Optima 2gb SD Card Write-Protection Problem
Ur right it has a physical problem. Try to format it using dos and then give it a try.
Thankyou
SOURCE: my 4gb microSd sandisk is infected and cannot be
It supposes to have a tiny lock/switch on the side. Move it up or down to turn off/on the write protection.
SOURCE: cannot delete in transcend micro sd 2gb memory card.
hi if you look on one side of the disk you will see a little white switch ( very small ) move this in the opposite direction of where it is and that should sort you out....hope this helps please vote thanks
SOURCE: How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
