SOURCE: Red light's on... but no hot water!
Just a bit of clarification; the lights and heating element are both downstream of the thermal protection ( I had mine apart and had a look). Therefore the lights would be off if the thermal protection had kicked in.
Lights on but no heat means element has a problem. Could be loose wire but more likely burnt out. If you have a tamper proof TORX bit you can take the bottom cover off and check for continuity through the element. Isolate the lights from the element so your meter is not accidentally seeing continuity through the lights.
