Ovens Logo
A
Anonymous Posted on Aug 27, 2013
Hi I HAVE AN SIEMENS OVEN HB43S540E AND CLOCK IS WORK BUT OVEN IS NOT WORKING
HB13AB550B-61 fan not working
see if voltage to fan motor if no bad board if yes bad motor
LED display on Siemens oven stopped working
HB 76AU.60 A Siemens oven display has stopped working
1helpful
2answers
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Hi I I have a Fisher Paykel range cooker model no: OR90LDBGX1 The clock is not working, the display is not illuiminated & the oven lamp is not working. The main oven won't come on as will only work...
the power runs through the clock then to the oven so delayed cooking can be set, toy have one of two options easiest is to by pass the clock,the second is to replace clock
Bottom oven switched off when setting timer. Can't get it to go on again. Oven is only a few weeks old.
Switch off from mains, reset the clock (not the timer) and it should work ok
My wall oven will not work. The clock is flashing '0:00 auto', I don't have a manual but the grill works???? Also tried pushing the buttons to set the clock and they don't do anything either???? Is this...
The clock will generally only be linked to the main oven. Can you comment on this post with the make and model and I may be able to assist with setting the clock, If the make is a siemens (as this is the section that you have posted the question in), follow the link below and download the manual to assist with the setting of the clock. All the best.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html open link and then click where indicated to open manual search, then input model number (Enr number).
Sep 04, 2010 • Ovens
24helpful
2answers
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
15helpful
The clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Dec 05, 2007 • Ovens
Top Siemens Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Siemens Oven Expert? Answer questions, earn points and help others
