Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power Engine cranks and runs good but will not develop power when you put it in gear. Engine was wave saturated during hurricane Ike. Has new starter, plugs, compression check (1) 150 (2) 150 (3) 155 (4) 175.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
409
Points
I have a 1974 135 jonhson runs but no power will not plane boat out did run fine last year i have clean carbs and new plugs and good compresson
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Apr 13, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
0
Helped
31417
Points
150
Sounds like a carb problem, you should have them cleaned and re-built
  • Anonymous Apr 13, 2009
    sounds like a carb problem, you should have them cleaned and re-built also could be water in the fuel
1helpful
SLK stalling problem
no if the fuel pump is failing it wont start. what about fuel filter ? what you can do is find a shop with a scope and they can check the fuel pump on it and look at the wave pattern and can tell you good or bad. but when it happens and you cant hear it it is time to check it properly before it leaves you stranded.
1helpful
Palm centro wont turn on
I had this same problem during hurricane ike. I thought that it was because the cell towers were down or something, but I eventually had to take it to the sprint store because nothing was working. I've had to get 2 replacement phones since then, so..good luck!
Power company turned power off for line repairs - tv no go since
most likely fuse, main a/c filter, shorted bridge-diodes. this occurs often when surges of up to 220v line is run into house. we've had alot here in south texas after HURRICANE IKE. good-luck mch
Blinking timer light - no power
Replace the power board and it should work, it got a spike from the unstable voltage of the generator
3helpful
Powermate pm0545005 generator engine runs but no power out
I posted a general "how to" about troubleshooting Powermates here.
Don't forget to rate answers you like,
Carl
Freezer section not cold enough/fridge ok
sounds as if you might have a compressor related sealed system problem, youll have 5 year war on such an issue from the manufacture
Motors fine, but no electricity - coleman 6250
pramac bought them out i just order parts today oct-15-08 call1-800-445-1805 took me awhile to get a hold of someone but she seemed to know what was going on. my guess is that the printed curciut board in the back of the generater head is bad i have had to change alot of these out.
JCD 2389 GES Not cooling
Yes. I would suggest the control board is possibly damaged.
Model jcd2389ges JENN AIR SIDE BY SIDE REFRIGERATOR Parts
This is not the only place to look, but it is where I would start.
Desktop won't start after Hurrican IKE power outage
the only thing i can think of is the power supply got fried that is the most common problem when it comes to the pc not powering on. Now hopefully that is all that it fried and not the motherboard my suggestion is to take to local pc repair shop and have them change your power supply or you could put it in if you familiar with how the machine is wired.
-replex
Top Light Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
john h
Are you a Light Boating Expert? Answer questions, earn points and help others
