Nokia Xpress Music 5130 Logo
nevilpatel Posted on Aug 28, 2013
My mobile restriction code unlock imei-354224030169096
4helpful
2answers
Enter restriction code
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
2answers
What's your problem?nokia 6300 restriction codes imei number352939/02/354728/7
Restriction code is nothing but the unlocking code for your mobile.
Unlocking your phone just removes the SIM card restriction so that you can use other network's SIM card.
To get the restriction code for your Nokia 6300 model mobile, just visit this site http://www.theunlockarena.com/nokia-6300/rs13wp9/,In this site just give your IMEI number , country & network lock after that within a short period
you can get the restriction code for your nokia mobile............I hope this is helpful for you.......
5helpful
CODE RESTRICTION NOKIA 2610 TYPE :RH-86
To get the restriction code for your Nokia 2610 model mobile, just visit this site Mobile-unlocker.com ,In this site just give your IMEI number , country & network lock after that within a short period you can get the restriction code for your nokia mobile............I hope this is helpful for you.......
4answers
Help me to unlock my nokia 5130c-2 T-mobile (USA) restriction code. My IMEI is 354220/03/096330/6 (354220030963306) TYPE RM 496 made in mexico. A Unlock Code ( 5766730464) received from Unlock-Free.c
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.
You can get the unlock code through online..........i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
1helpful
How to unlock restriction code for nokia 2320c-2b IMEI 011975007220924
hi restriction codes is nothing but the mobile is restricted to particular network to solve the problem we can use codes to unlock .you can get the codes from here theunlockarena here they ask
the following details they are mobile model,country and the network which locks your mobile ,imei
number of the mobile .finally they will send the codes to unlock the mobile.once you entered the codes in your mobile your mobile get unlocked and it will be free to accept any network sim.
3answers
My Nokia phone is restricted. I WANT THE RESTRICTION CODE,PLS. the model is 5130c-2
hi,
in this case you must contact your network to solve your problem.
gorbesia
2answers
How to unlock restriction code from nokia 5310 xpress music
- If the problem is security lock (forgot or lost etc) of your mobile,
- I can help you if you provide me with the IMEI code of your mobile phone.
- With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by typing
*#06# into the phone keypad.
Please leave a comment and rate if this solution helped you, thanks!
Jul 22, 2011 • Cell Phones
86helpful
30answers
Hello sir
Default security code for your mobile is 12345
but if you have changed it to any other name ,then you require unlock code or master code..to get unlock code IMEI no of mobile is needed.unlock code is calculated on the basis of mobile model no and IMEI no..to get IMEI no of your mobile type *#06# at the screen and you willl see IMEI no..
Please don't forget to rate this solution and let me know your IMEI no .so that i can give you unlock code for your mobile and you will be able to crack the restriction code.
Jun 23, 2008 • Nokia 3220
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
