SOURCE: fridge not cooling
Most of the time on a whirlpool the problem is the relay on the compressor sometimes called the start device. I would replace that first. If you need help finding the part let me know. I will need the complete model # from the sticker inside the fridge section. You can look it up with diagrams at http://www3.sears.com/.
SOURCE: Whirlpool Side by Side Fridge Not Cooling
i have a side by side and the refrigerator side is not cooling
If you have already tried shutting off for 24 hrs. (reset), cleaning the under-bed condenser fins (vacuum and/or compressed air) and the issue still continues, you may be lucky enough to just need a relay/overload switch; the thingy connected to the compressor, which by the way takes patience and ease in removing. However, once the plastic cover is off, simply unplug the relay switch(s) and shake it, if you hear rattling (or) smell burn, the relay is toast and thus needs replacement. Simple enough, for replacement type in the model # of the compressor: (i.e.) [[ Embraco FGS 80 with relay/overload switch ]] cost around ($30-$50)... order, replace, re-plug, and if on target, the compressor will kick in. let run for 24 hours before adding foods, and all is good. Have a nice day. ee
SOURCE: Freezer not freezing, refrigerator warm, hear clicking sound
The overload/relay on the compressor is shorted . This is the piece with 2 or 3 wires connected to it , mounted on the compressor . The part # you need is 8201786 . Complete mounting instructions , come with this kit . Easily replaceable .
SOURCE: whirlpool gold GD25DF FRIDGE NOT COOLING FREEZER WORKING FINE
Clean out the coils at the very bottom of the refrigerator from all of that lint/dust buildup it makes your system inefficient
The model number shown in the question is not correct. I have a Whirlpool Gold Model number GX5SHTXVB00. It has a bottom freezer with ice maker and a double door on top.top.
