Unable to register the twx977 submersible phone to any base. It came with the Tru9485 series. Please help.
Push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Disconnect the base AC adapter.
•While holding the [find hs/intercom], reconnect the
AC Adapter.
•On the handset, press and hold [#] until the display
reads HANDSET REGISTERING and you hear a
beep.
Push and hold the the Red Hang-Up key and the # key at the same time. Two options will appear on the handset. Select "Base Station Unavailable"
Confirm with the "YES" option and the handset will display "Handset De-registered"
From the Base Station, select menu and then "Register Handset"
The base station will display a message stating, "On handset, hold # key for 2 seconds"
Press and hold the # key on the handset for a few seconds and you will hear the beep as the phone and base station confirm registration.
Done
I had a similar problem with a regular handset that I ordered separate to go with my base. Taking the battery out wouldn't reset it. If you push the red hang up key and the # key for at least 5 seconds, it will give you the option to deregister it, even if you don't have it registered to a base. It reset it brand new. Tried registering it again, and it worked! HTH
This is the solution that came in the owner's manual. It doesn't work. Been trying for two days. Any other thoughts? I'm going to take the battery out and do a hard reset that way.
The menu for TRU9485 doesn't have a REGISTER HANDSET selection as the manual says that it does. Have tried the other method for other models as suggested and that doesn't work either. Anyone find a solution?
me too - help!
I did what you said I disconnect adapter from the base, and then
hit the # key, and it said handset registering, and then it said
register failed. Now what?
