could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out
www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
that has nothing to do with it. this is happening to my 800 too. your wrong.
I just got a pair of eltax pyramide 400W, and when i play musik with just a little bass in it i can only tune it up to volume 2 on the Pioneer a449
