If you need the Restriction code to remove the network lock from Nokia 6233 mobile phone visit the site ClassicUnlocking.com here you can get this code at low cost with easy step by step unlocking instructions and unlock it.After unlocking it,you can use freely any GSM network SIM card.This is the safe,fast and permanent unlocking method.
SOURCE: RESTRICTION CODE
6030 network unlock imei number 010689000054161
please give me code
some problem i will do it jaf box restore factory setting after on mobile start but some problem create error no network found..
plase help meeeeeeee
SOURCE: restiction code or factory set code for NOKIA 6233
ALL NOKIA PHONE CAPABILTIY TO ACCEPT ALL BRANDS OF SIMS SO THERE IS SETTING ROBLEMS IN UR PHONE factory setting UR PHONE WILL HELP U IF ITS NUTS SOLVE IT THAN
REMOVE MMC BACK UP OF ALL UR DATA FROM PHONE MEMORY INSTALL NOKIA PC SUITE IN UR PC AND DOWNLOAD UPDATES FOR NOKIA MOBILE FROM NOKIA.COM INSTALL IT AND UPDATE UR MOBILE ONLINE.IT WILL FORMATE UR MOBILE AND RESET UR CODE TO 12345 AND ALL SETTINGS
SOURCE: nokia 6233 restriction code
Fellow, I can unlock the code, but the problem is I need to be in Live contact with you.
Regards,
Waqar.
SOURCE: what is the phone restricted code for NOKIA 6233
try this #pw+404767725207222+1
not solved yet then update your frimware
please leave me comment
