Thats basically the problem. The washer will fill up with water and then as soon as it gets to the rinse the cycle it just turns off. so if i could please get some help it would be appreciated
If your washer fills, agitates, but won't spin out to rinse, this is usually a symptom of a bad lid switch. The switch is usually located on the right hand side of the washer tub opening around the rim where the lid seats. There is also a plastic plunger on the lid that will push down on the switch when closed to make contact. On some models, the lid switch is located on the left hand side of the lid in the rear. It is controlled by an armature on the hinge of the lid closing the switch contacts. Check the switch by opening and closing the lid. If you do not hear a distinctive "clicking" sound of the lid switch, the switch isn't working and/or the plunger may be broken off. If you can provide your exact model number (located under the lid of the washer along the rear rim of the tub opening) I can tell you which type of switch you have and the part number. Let me know if this is helpful. This is a very common problem with this model washer and a simple fix.
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
SOURCE: Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
SOURCE: won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
SOURCE: My Maytag Neptune front load washer continues to fill with water.
For troubleshooting assistance please click on the following link
http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
