SOURCE: Spark Plug for Briggs & Stratton Engine
you'll need a champion J19LM [or RJ19LM, same plug except the RJ is a resistor plug]
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
SOURCE: Briggs and Stratton 6.5 hp won't start- not sure
Took carb. off and cleaned and put new kit in. Carb. is self choking. Put new primer bulb in. Will run with starting fluid then stop. Not getting any gas. Could carb. be clogged. I soaked it in carb. cleaner and blew out. Any suggestions would be greatly appreciated.
SOURCE: Craftsman Mower - 625 Briggs
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
SOURCE: 4.5hp briggs and stratton hunting even after carrb and diaphram replaced
did you get the right carb and its not from a larger engine?
