SOURCE: my DVD recorder won't play my CDs
Recently purchased a unit... You can imagine the joy when I found in Manual: Audio discs can only play if in .mpg or .wma formats! Yes, all the bells and whistles except the most basic of functions such as all common audio formats. Other portable $99 dvd player works with them.
SOURCE: Navigation upgrade for 2007 9-3 Aero
You will have to have it programmed at a Saab dealer. It wouldn't hurt to remove the old EHU (radio) and see if you have different connectors. Remove the screw covers (4) carefully and remove the screws. Then it will come right out. I think there are different connectors which would mean you are screwed but I am not sure. Make sure you have the Nav. DVD.
SOURCE: Radio not playing
it sounds like you didn't hook up both your power wires on your cd player. there is a red and yellow power wire. one is constant power to keep memory and the other turns on the radio when the key is turned. check to see if both are hooked up
SOURCE: left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
