Washing Machines Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The washer will not wash all
At first the washer would leak when it ran but that problem ceased and only came back when the tub was overloaded. Now the washer will not work at all. If you turn the dial to rinse the tubwill fill with water but nothing else will happen
Anonymous
Level 3:
President:
  • Master 1,294 Answers
  • Posted on Apr 11, 2009
Anonymous
Master
Level 3:
President:
Answers
1294
Questions
Helped
901099
Points
3465
Brand of washer, model; front-loader? You can try this:
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
2answers
Whirlpool WTW5100VQ2. Think it needs water intake valve it drips inside continuously even when off. Last night during a load it leaked alot from underneath. Is this diff problem or intake valve also?
Sounds like your water valve is leaking. If you shut the water valves off at the wall and it stops then for sure your valve is leaking. The leaking from under the washer could be coming from the pump leaking, overloading, hoses leaking on the connections or a tub seal. I would check the pump first, just tip it back a little and see if you feel water on the pump, it's right up front. This washer is very easy to work on.
I disassembled doors front and back and found a pin hole leak in the tub tonight. Looks like a 1mm hole in bottom left of tub (when looking from back). I ran a cycle and 100% certain water leaking from...
check that there is a small tube in the area as it is around that spot that the pressure hose goes up to the water level selector switch
otherwise use a short metal thread screw with a fibre washer under the head to plug the hole
you can get screws as short is 3/8 to 1/2 " and thick in diameter to fit into the hole
too long and it will bind up on the wash tub
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Leaking and F51 error code on my Kemore Elite Oasis Washer
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer.
Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
I think a overloaded the washer and it wouldnt spin.
Frigidaire washer will not take a overloaded tub without causing belt problems.
Unplug the washer.
Remove the 2 screws on the very bottom of the front washer panel.
Slide the front panel down slightly and remove it from the cabinet.
Inspect the belt around the motor pulley and transmission.
If it is worn at all it needs replacing.
You could plug the washer back in and set it to Spin cycle and watch for the motor to turn and the belt slipping to verify a bad belt.
Keep your hands,fingers and tools away from all moving parts.
2answers
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
2answers
Overloaded washer and won't drain
hi,sounds like you have a blocked pump,
Maytag Neptune FAV6800AWW top loader washer
Double posting, are you still having the issue, did reseating the clutch clear the issue?
Washed clothes while on the 'clean washer' setting
I'm sure that the exact make up of clean washer or tub clean cycles vary from brand to brand, but basically that cycle fills to a higher water level, hottest water, and highest spin, turning off load sensors / out of balance sensors so the machine can spin with water in the tub (allowing tub cleaning agents to contact all tub surfaces). (all other cycles pump the water out before spinning) Having a load of clothes in the machine at this time could result in overloading machine (gererally causing an error code), damage to suspension components, damage to hoses or connections resulting in water leaks, etc. Due to the large water level, your clothes would be agitated more ****, but the hot water might damage some fabrics. A FixYa rating would be appreciated for this info. Thanks.
Top Washing Machines Experts
john h
