ou can use a pass code - a button sequence on your controller - to control access to your Xbox Live account. Once the pass code is set, anyone who wants to use your profile must enter the pass code before signing into Xbox Live.
Go to Settings, select Account and then select Account Security.
Select Pass Code.
On your controller, enter a four-button code by pressing X, Y, the triggers, the bumpers and the directional pad.
From the System area of the Xbox Dashboard, select Family Settings, Console Controls.
Enter an incorrect pass code.
You will be told that your pass code is incorrect. Select Reset pass code.
You will then be shown your pass-code question and asked to answer it.
Type your answer using the on-screen virtual keyboard and either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console. Your answer is case-sensitive and must be typed exactly as you entered it originally. This will clear your original pass code and allow you to enter another.
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to
control access to features and options. Because Family Settings exist
for both the console and for Xbox LIVE accounts, you can set pass codes
for both. Here you can learn how to:
Set an Xbox LIVE Pass Code When
you set an Xbox LIVE pass code for your profile, anyone who wants to
use that profile will need to enter the pass code before signing in to
Xbox LIVE. To set an Xbox LIVE pass code:
Go to My Xbox and open your profile.
Select Manage Account, Xbox LIVE Pass Code.
Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You
will have to enter your original Xbox LIVE pass code before you can
create a new one.)
Set a Family Settings Pass Code When
you create a Family Settings pass code, anyone who wants to change
family settings on your console will need to enter the pass code first. You can also use your Family Settings pass code to override game
and movie settings if you (or those with whom you share your pass code)
want to play games or watch DVD movies that your console settings
normally block. For example, you could give the pass code to your 18-year-old so
that she can watch R-rated movies that your younger child is not allowed
to see. To set a pass code for your console:
Go to My Xbox and open System Settings.
Select Family Settings, Console Controls.
Select Set Pass Code.
Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
Choose a pass code reset question.
Select Pass Code Reset Answer and enter
your answer using either your Xbox 360 controller or a standard USB
Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
To reset your pass code, repeat this procedure at any time. Reset a Forgotten Pass Code To reset your pass code after you've forgotten it:
You'll be told that your pass code is incorrect. SelectReset pass code.
You'll then be shown your pass code question and asked to answer it.
Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as
well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX
(1-800-469-9269).
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-555-741. They will resolve the issue for you
