Apple iPod MA446LL/A MP3 Player Logo
Anonymous Posted on Aug 26, 2013
Ipod does not respond to screen touch - Apple iPod MA446LL/A MP3 Player
4 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Aug 05, 2008
SOURCE: ipod nano not responding
http://serviceman.site88.net/index_files/Apple_Ipod.htm
Anonymous
  • 73 Answers
  • Posted on Apr 09, 2009
SOURCE: ipod touch frozen
wait for the battery to die. when you charge it again it should work
Anonymous
  • 1285 Answers
  • Posted on May 23, 2009
SOURCE: my ipod touch has stopped responding
try this http://www.everymac.com/systems/apple/consumer_electronics/ipod_faq/ipod-how-to-restart-frozen-begin-troubleshooting.html
hopefully this will do it
Anonymous
  • 183 Answers
  • Posted on Jun 21, 2010
SOURCE: Ipod touch (2nd Gen) with water damage
The touch screen is not physically attached to the screen, if water was anywhere near the bottom of the ipod it may have triggered the water damage unit inside the bottom. Water also may have leaked into the unit frying the circuits. You'll have to visit an Apple store or Apple.com/support for repair.
How to enter my password when my screen is black
Try to Restart iPod touch by until Sleep/Wake button until a red slider appears.Next, turn iPod touch on. If iPod touch not responding reset iPod touch, press and hold the Sleep/Wake button and the Home button with same time least 10 seconds, until the Apple logo appears.
If still screen not appear than Recharge iPod touch or try To restore your iPod touch, first make sure you are using the latest version of iTunes(by http://support.apple.com/kb/HT1414). If still not able to solve than take some help with Apple Support Number .
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
My ipod
The iPod is a portable music player made by Apple. As of early 2011, Apple sells four models: iPod shuffle, iPod classic, iPod nano and iPod touch. If your iPod experiences a problem such as not responding or freezing, you can reset it to see if that takes care of the problem. IPod Shuffle The iPod shuffle is the smallest iPod model, with 2GB of storage.
It has no screen and attaches to your clothing with a clip, making it well suited for exercising while listening to music.
When it doesn't respond, or if the status light is solid red, you can reset it.
Slide the three-way switch left toward the word "Off," covering the green bar. Wait 10 seconds, and then slide the switch back to reveal the green bar to turn it back on.
IPod Classic
The iPod classic has a 160GB hard drive for storing music, videos and pictures.
If it experiences a problem, you can easily reset it.
Slide the "Hold" switch to the "Hold" position and then slide it back.
Press "Menu" and the center button simultaneously on the click wheel and hold them for about six seconds, until Apple's logo appears on the screen.
IPod Nano
Apple's iPod nano has a touch-screen display and comes with 8GB or 16GB of storage, depending on the configuration.
It has a pedometer and an FM radio.
If the iPod nano doesn't respond, reset it.
Press the "Sleep/Wake" button and the "Volume Down" button simultaneously and hold them until the screen gets dark, and then wait a few more seconds until the Apple logo appears on the screen, followed by the home screen.
IPod Touch
The iPod touch has a touch-screen display, two cameras for shooting pictures and movies, and Wi-Fi for accessing the Internet. Its capacity ranges from 8GB to 64GB, depending on the configuration.
You can use the iPod touch to send email and make video calls, as well as play games and run applications. If the iPod touch freezes or otherwise isn't working, you can get it running again after resetting it.
Press the "On/Off-Sleep/Wake" button and the "Home" button simultaneously for at least 10 seconds, until Apple's logo appears on the screen.
Unlock
IPod Classic
IPod Nano
IPod Touch
Hi there my daugters ipod touch 8gb screen gone white and does not respond when you press the screen
You may need to reset. Important: Only reset your iPhone or iPod touch if it is no longer responding. To reset, press and hold the Sleep/Wake button and the Home button together for at least ten seconds, until the Apple logo appears.
My touchscreen will NOT respond
Please follow this video to reset your iPod touch:
http://www.youtube.com/watch?v=Yzf-vUgM0Aw
Thank you
TechSaver
3helpful
Ipod touch 8 gb. The screen is frozen
You must attempt to refresh your iPod Touch.
Hold the Sleep Button and the Home Button at the same time for 10 seconds. The screen turns off, wait for 5 seconds. Then hold the power button again until you see the Apple Logo. Wait for couple of seconds. Then your problem should resolved!
If this does not work, let me know. :).
Screen not responding to touch
try to reset your ipod settings, go to settings,general,reset all
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
