Lenovo ThinkPad T400 Notebook  6474T1U Logo
Anonymous Posted on Aug 26, 2013
Unlock keyboard not working button
mailboy
Level 2:
New Friend:
  • Expert 54 Answers
  • Posted on Jan 16, 2015
mailboy
Expert
Level 2:
New Friend:
Answers
54
Questions
0
Helped
6224
Points
106
Instructions
    • 1 Locate the "Fn" key in the lower left corner of your Thinkpad keyboard.
    • 2 Locate the "F2" key in the upper left area of the keyboard.
    • 3 Press and hold the "Fn" key, then press the "F2" key to toggle the "Lock" feature. Release both keys.
How to Unlock an IBM ThinkPad T60 eHow
Unlock child lock
Instructions
    • 1
      Open the Acer laptop and turn it on. Allow the user to complete all startup procedures before pressing any buttons on the keyboard.
    • 2
      Locate the "Windows" button. It is located on the bottom left-hand side of the keyboard and has a dark circle with a little waving flag inside. Locate the "L" button as well.
    • 3
      Press both buttons at the same time. The laptop keyboard is now unlocked. Test the computer by trying to open a file on the computer. If the keyboard did not unlock, repeat the procedure and be sure to press the buttons at the same time. The keyboard will unlock.
2answers
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    2answers
    How do i unlock my dell keyboard?
    Dell Inspiron 530s keyboard unlock
    Is the keyboard usb or ps2? If its usb then try another port. If its ps2(Green) then power down the pc by holding in the power button for 8 to 10 seconds. Pull the plug and make sure no pins are bent. Plug it back in and boot back up. This should fix the problem if its ps2. Regards
    My acer extensa 4630z laptop's keyboard is not working mouse pad left and right click buttons work fine. I tried the fn f7 buttons but nothing works any ideas? The buttons worked fine yesterday.
    try blowing out the dust and particles from under the keys. Are you in NumLock, if so hold the "fn" button down and press your F11or which ever F key says NumLk on it , that should unlock the keyboard. Depending on the age of the unit it is possible that it just may need replacing.
    11helpful
    5answers
    Acer Notebook Keyboard is locked
    Just hold down Fn then press F7 or F8 keys to unlock keyboard.
    Good luck.
    12helpful
    .My Keyboard is locked-I cant unlock it.
    Steps to unlock HP laptop keyboard.
    1. Turn off the computer
    2. Remove the battery.
    3. While the battery is out, hold the power button for about 30 secs
    4. Put back the battery
    5. Turn back on the computer and it should be good to go.
    4helpful
    2answers
    Microsoft wireless laser keyboard 6000 v2.0 has locked up. how to unlock?
    for the laser 6000 v2
    hit the reset button on the wireless receiver (oval button)
    THEN
    hit the small white reset button on back of wireless keyboard (it's called Connect Channel)
    presto!
    KRZR k1....
    It sounds just like a keyboard lock and you need the code to unlock it. though it should be prompting you,
    if you push * and # on the same time your keyboard locked. When you press it again, you unlock your keyboard
    Your phone’s four-digit unlock code is
    originally set to 1234
    The six-digit security
    code is originally set to 000000
    If you forget your unlock code: At the
    Enter Unlock Code prompt, try entering 1234 or the
    last four digits of your phone number. If that
    doesn’t work, press s and enter your
    six-digit security code instead.
    If you forget other codes: If you forget your
    security code, SIM PIN code, PIN2 code, or
    call barring password, contact your service
    provider.
    hope any of this helps .
    6helpful
    2answers
    Keyboard not working
    On another thread i found the solution:
    [Ctrl]-[Alt]-[F12] (must use the left [Ctrl]-[Alt] keys, not the right)
    Push the Connect button beneath the keyboard, then the Connect button on the USB Receiver, then the [Esc] key on the keyboard.
    This will unlock the security encryption on the keyboard. You may need to reconnect the mouse afterward too.
    1helpful
    2answers
    How do I unlock the keyboard
    Hi There If youyr lights above the Num Lock Button are on then i would serggest you try unplugging your key board and restsrting your PC when the PC pings the replace your keyboard and check that the lights are working by pressing the Num Lock Button this should let you use the numbers hope this works Paddy
    Top Lenovo Computers & Internet Experts
    Steve Sweetleaf
    Steve Sweetleaf
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
