I have a amd sempron k7s41 gx motherboard i just upgraded to vista but neither the sound nor the vga drivers seems to be able to install as i keep getting incompatibility messages what can i do
Windows 7 Will be out soon! With Windows 7 You have a built in XP mode which basicly lets you use Windows XP virtually through windows 7 without you having to do a dual boot or restart your computer. But be warned though as on june 1st 2009 and after, windows 7 will expire meaning you will not be able to boot. Before this, Buy a copy of windows 7 or use a previous version of windows, and then when you have enough money, buy the completed version of windows 7. Windows 7 will offically be realeased on October 22nd, When you install Windows 7 RC (Release Candidate) Do a clean install i.e. formatting your hard-disk(s). Backup all your important files on an external Hard-Drive. After windows 7 has finished installing and boots up for the first time, your drivers for everything should be automatically detected and installed. Windows 7 has built in drivers for nearly every manufacturer. You may download the Release Candidate via the following link:http://www.microsoft.com/windows/windows-7/download.aspx - You will need to choose 32-Bit as your motherboard and proccessor do not support the 32-Bit version. You should not have any compatibility issues as Windows 7 is created to run on computers as old as 5 years. You will need a blank 4.7GB DVD disc and an ISO image burner as the downloaded file is in the ISO format. You may download IsoBuster Via the followind link:http://www.isobuster.com/isobusterdownload.php - Save both the Burning software and Windows 7 file in a place which you will know of i.e. Desktop or documents. I hope this post has enabled you to fix your problem. Regards Sohaib
I need sound driver because after fomatted no sounds
