As long as the printer is connected to the computer (Laptop HP Pavilion dv6700) with 64 bit Vista, the computer (vista) seems to install a driver for the printer automatically, and the driver and HP toolbox on the CD provided with the printer cannot be installed. As a result, the printer cannot scan a file to a pdf file even though it can print files.
Try this:
First put the cd and installation wizard will come up ...goto install more sw>>install ocr .....
Now scan will get the options.
or
Now for the 2nd opt>> put the sw cd if you have right click explore ..(goto step 3) but if you dont have the cd you can download the sw from hp.com >support and drivers..extract the file and goto run(search bar for vista) type "%temp%" and then click on folder starting with 7z....now goto step 3.
step 3.goto util folder>>ccc>>unistall l3 but make sure you have to unplug the usb first.
>>Small black box will appear and press enter...and wait it will unistal the printer sw.
>>goto printers and faxes folder under controlpanel (printer for vista)...chk if there is any hp printer any more...if there is any printer not in use..delete them.
>>restart the sys and then install from the downloaded sw only but make sure you should include ocr sw if you are installing it as a custom installtion other wise everything fine.
now scan everything will work.
let me know.
Best wishes,
Suvrajit
SOURCE: Scan format - Samsung SCX-4521F to PDF
samsung scx 4521f in black background in more verticle white line in
SOURCE: MCF 6490CW SCAN AS A PDF
I was trying to figure out how to scan multi-page documents to a single file and found this on the Brother website:
Double-click on the ControlCenter3 icon located in the Task Tray to launch the program window.
Click on CONFIGURATION -> SCAN.
Choose the type of scan you require. The choices are: IMAGE,
E-MAIL, and FILE.
The Scan to configuration window will appear.
The SOFTWARE BUTTON tab configures the Scan to button within theControlCenter3 software interface. The DEVICE BUTTON tab configures the Scan to key on the Brother machine. Choose the tab you want to configure.
Under FILE TYPE select an option that allows multi-page documents:
a) PDF (*.PDF)
b) Tiff Multi-Page # Uncompressed (*.tif)
c) Tiff Multi-Page # Compressed (*.tif)
Click OK.
SOURCE: Scanning Multiple pages into one pdf
Typically it is possible, in advanced settings for scanning it will typically give you an option to scan multiple pages into one document.
SOURCE: 64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
SOURCE: Samsung scx-4521f-How to scan multiple pages to single pdf file?
get acrobat professional, its pricy, but it workes
Compatible Systems: Windows 7 32-bit, Windows 7 64-bit, Windows Vista 32-bit, Windows Vista 64-bit, Windows XP 32-bit, Windows XP 64-bit
View all downloads for Windows 7 64-bit in the sections below, or select a different operating system above to reveal other downloads for your product
