SOURCE: Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: Sharp microwave runs when door closed
This is usually caused by either a bad door switch, a loose door switch mount, or sometimes a problem on the control panel.
I would suspect the door switch mount has a broken tab allowing the switch to swing down when the door is closed, not allowing it to really be activated.
Also, even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes
Failure
Code
Condition
Check/Repair
F1
Open sensor, will
occur below 190F of cavity temperature within 15 minutes after
starting convection, combination or roast cook
Check oven temperature
sensor for continuity. Replace if zero or infinite ohms
F2
Shorted thermal
sensor, will occur if a shorted thermal sensor is detected
continuously over 5 seconds on convection, combination or
roast cooking
Note: It will take a minimum of 5 minutes of convection run
time before F1 or F2 code will be displayed if the thermal
sensor is shorted or open.
F3
Shorted key panel
(touch pad), will occur if a shorted key panel is detected
continuously over 60 seconds
Replace key panel
(touch pad)
F4
Open humidity
sensor, will occur if humidity sensor is detected as being
open continuously over 5 seconds
Replace humidity
sensor
F5
Shorted humidity
shorted continuously over 5 seconds
Replace humidity
sensor
F6
Shorted temperature
probe, will occur if temperature probe is detected as shorted
Replace temperature
probe
ProbEe
Open temperature
probe, will occur if temperature probe is detected open, or
not plugged into the receptacle
If probe is plugged
in and "ProbE" is on display check continuity of the probe
with an ohm meter. If zero or infinite ohms, replace it
SOURCE: Microwave door not closing properly so will not work
Throw it away and get another microwave
SOURCE: change inside microwave light GE profile microwave
open the screw and then full out the side and top cover
