My Blackberry Pearl won't stay connected to the radio. When I restore the connection manually, it only stays connected for 16 seconds each time. The battery is showing that it has 3/4 of battery left on it, and I talked to tech support at Sprint and they just told me to reset the device, which I have done, I've also taken the battery out and replaced it. They also told me to start provisioning...which takes forever and I have to manually cancel that as well.
I've read that other people have had the same problem but I have yet to find a solution.
Thanks!!
If it was spotty reception, I'd suggest the antenna may have been damaged when dropped. They do get damaged.
But systemic, timed 16 second bursts?
In Settings, when is your phone configured to 'go to sleep'? After how long a period of inactivity?
It may not be considering the radio signal is be sufficient activity to justify keeping it 'awake'.
SOURCE: Blackberry Pearl/unprogrammable
have you tried doing a hard reset of the device? go to Settings, Options, Security Options, General Settings, Device Wipe.
SOURCE: the radio on my blackberry pearl will not stay connected
Try this:
Options> Mobile Network> now press the BB menu key> Diagnostics> Now press the BB menu key again Run
SOURCE: I have a treo 755p sprint phone. I also own a
SPRINT DOESNT USE SIM CARDS ON THEIR PHONES THEY ARE CDMA (Code Division Multiple Access) AND IS NOT GSM LIKE ATT AND TMOBILE, YOU NEED TO CALL SPRINT AND PHONE SWAP THE ESN (ELECTRONIC SERIAL NUMBER) NUMBER UNDER THE BATERRY AND GIVE THE ESN TO SPRINT.
SORRY
SOURCE: i want the 8 or 16 digit code to unlock my blackberry pearl blue
http://www.blackberrymep.com Best way to unlock your blackberry .
SOURCE: BlackBerry Pearl 8100: blackberry pearl roller ball sticks...
it is because of the dust accumulate din between the trackball and the wheels...so remove the trackball and clean it....u can be abe to do it by your own... for assistance watch this video,to solve this problem http://www.youtube.com/results?search_query=blackberry+pearl+8100+trackball+repair&aq=f
