I just moved into a new place with this dishwasher. The first time I tried to use it the metal part that sits next to the sink filled up with water and started spilling onto the counter. I am not sure if it was supposed to be spilling into the sink, but it went everywhere so we just stopped the wash cycle. What do I need to do to fix this?
Almost all dishwashers connect to the sink drain in one way or another. Many connect (via an Air Gap valve) to a garbage disposal.
If the "metal part" is at the rear of the sink, that is the top of the air gap. When water comes out of it, that means the drain is plugged.
If there is a garbage disposal, does water drain through it? Does the disposal work?
If there is no disposal, does water from the faucet run through the drain of each sink with no problem?
Thanks for answering these questions in a reply.
Two things to consider....clean water or
dirty water?
Clean water usually indicates the fill valve
is not shutting off all the way and the fill valve is "weeping" water
in all the time = new fill valve time!!
Dirty water usually is not a dishwasher
problem but more of a plumbing issue. Often the sink drain that carries the
sinks water outside is not fast enough and some of this sink water is backing
up into the drain hose and filling up the dishwasher through the drain hose.
The drain from the sink to outside needs attention as this type of a problem
indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
dirty water?
dirty water?
dirty water?
dirty water?
Thank you for responding. There is a disposal, but it works fine and the sink drains.
Thank you for your help... I've never owned a dishwasher before.
