SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
SOURCE: kenmore 5022 please help
Do you have a heavy frost on the rear panel of the freezer section? If so, you have a defrost system problem. If you will post the complete model number I can help you diagnose which part you need to fix it. In the meantime, you can manually defrost it and it will work for about a week or so until the frost builds back up.
SOURCE: Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
SOURCE: Kenmore Side by side unit has stopped working
turn both dials to 5 and wait for an hour, when it first conmes on they go into a defrost automatically, the defrost controller isa in the upper left hand side of the refrigerator compartment and may be an adaptive technology one that is just a circiuiot board thats about 4 by 4 and behind the area thats betwqeen the back dammper and the front of the unit. It may have fried and that wopiuld explain why your frig does not work.,
SOURCE: ice buildup on floor of side by side freezer floor..
Inside the freezer in the lower part of the back wall there's a drain hole wich probably is clough and the water from defrost doesn't go through and freezes up .Put hot water to defrost it and keep pooring it until goes through.If is still clogh try with a wire but do it ery carefull to not put a hole in the drain plstic tube.
