Question about Sew D'Lite 11401 Mechanical Sewing Machine
Can this machine do zigzags? - Sew D'Lite 11401 Mechanical Sewing Machine
  • Sew D'Lite Master
  • 6,073 Answers
The Sew Dlite 11401 shown on Amazon here, http://www.amazon.com/DLite-Supreme-Portable-Sewing-Machine/dp/B0006BDG8Q , does not do zigzags. It only does straight stitches. There are similar models that have a stitch width lever. Those do zigzag stitches and straight stitch when in the zero width mode.
I hope this helps.
Posted on Aug 25, 2013
  • Kamila Quinones Aug 25, 2013
    Thanks Cindy
  • Cindy Wells Aug 25, 2013
    You're welcome. Cindy Wells
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
My Bernina 830 sewing machine will not do a zigzag stich
We are assuming that the zigzag width dial is at the widest position but the needle will not move laterally for zigzag... The following logic should be applied for Bernina machines 530, 730, 830, 930 machines with a guided motion zigzag cam.
1. The switching pawl (lever on the top cover that switches from zigzag to cam patterns) may be engaged in the cam or automatic pattern side. Check that first.
For zigzag application, the lever must be engaged in the zigzag side (lever pulled back toward the operator). The stitch width dial is then used to provide your choice of width.
2. It is common, due to oil varnishes, that the switching pawl that is actuated by this lever is stuck between the zigzag and the automatic position, thus preventing the transmission of power to either the zigzag cam or the automatic pattern cams and to the needle.
The best way to detect this is to remove the top cover. You can then switch the lever back and forth to observe if the switching pawl engages firmly into either of the receiving forks. If the switching pawl is sticking, a few drops of certain solvents are applied by a technician on the switching pawl support. The switch lever can be rapidly switched back and forth until you see the switching pawl engage into the receiving forks and you hear a crisp clicking during each engagement. This repair can be permanent or it may create only a temporary fix due to the amount of oil varnishes on the parts.
If the machine is heavily varnished, it suggested that the parts be disassembled and cleaned for flawless performance. If the machine had been sprayed with WD-40, petroleum based solvents like mineral spirits will not break down these varnishes.
A caution regarding solvents...DO NOT USE (WD-40) as your solvent. WD-40 is a marvelous product for its intended application as a water displacement device. It is not to be used for lubricating a sewing machine. Note: "Bernina Technical Information bulletin #1" issued in 1982, forbade the use of such spray lubricants and solvents. SewTechnical Home
Sep 28, 2014 | Bernina Sewing Machines
Breaking thread while zigzagging
on most machines you must substantially reduce the needle tension when sewing zigzags
Mar 02, 2014 | Sewing Machines
Not stitch zigzag
Have you tried a needle change? It could be blunt or the wrong size. Have you cleaned under the needle plate as the ridges get full of lint there. A toothpick will clean them out.
Nov 22, 2013 | Singer 1120 Mechanical Sewing Machine
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
I forgot how to set the machine to zigzag, Does
There is a Yahoo group for owners of Kenmore machines. They might be able to help you. http://groups.yahoo.com/group/vintagekenmoressew/
Also, I just found an instruction manual available for a good price on Amazon also: http://www.amazon.com/Instruction-Manual-Kenmore-Zigzag-Machine/dp/B001PVAR5Q
Oct 20, 2009 | Kenmore Sewing Machines
Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Jan 13, 2009 | Brother LS-1217 Mechanical Sewing Machine
Will not zigzag
Have the hook timing checked on your machine.
Oct 09, 2008 | Sewing Machines
Sew D'Lite 11401 Mechanical Sewing Machine Logo
107 people viewed this question
Top Sew D'Lite Sewing Machines Experts
Renee Knafel-Bullock
Jimmie Sill
Are you a Sew D'Lite Sewing Machine Expert? Answer questions, earn points and help others
