SOURCE: How do I disassmble a jado kitchen faucet with
you have to locate the water shut off valves before you attempt removing the water lines, hopefully they will be located on the lines under your sink, if not you will have to shut the water main off coming into the house. After you have shut the water off and disconnected the lines, look under your sink at the back were your faucet comes through the sink and you will find the fasteners, unscrew these counter clockwise and the faucet will lift out .
I happened upon the solution - there's another check valve in one of the nut connectors. Removed that one, put the one back into the sprayer, and now we're cooking with peanut oil! :)
