Was using zigzag stitch when this happened. Won't feed with straight stitch either
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Have you cleaned and oiled your machine? Feed dogs especially require oil. Check your manual, follow the instructions, and use good quality oil (Bernina oil for mechanicals is excellent).
Could you have accientally lowered your feed dogs?
