Health & Beauty Logo
A
Anonymous Posted on Aug 25, 2013
Bags dazey seal meal - Health & Beauty
David Payne
Level 3:
Top Expert:
  • Master 14,162 Answers
  • Posted on Jan 10, 2016
David Payne
Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998498
Points
455836
Gadgets vs107 top and bottom rival seal a meal
ind helpful customer reviews and review ratings for Seal-A-Meal VS107 ... Also, you don't have to search for Rival bags..any 5-mil vacuum seal bag will ... Two things, you have to get the top of the bag straight and flat for it to make the seal. ... I checked out lots of different brands before deciding to buy this lower cost model.
After hands-free red light for sealing turns on, why does it take a long time to start sealing?
Seal-a-Meal FSSMSL0160-000 Vacuum Sealer - Amazon.com
www.amazon.com > ... > Vacuum Sealers
Amazon.com, Inc.Handy indicator lights for "Hands-Free" and "Sealing", plus Open/Cancel button. Keep your busy kitchen running smoothly with help from this easy-to-use Seal-a-Meal ... With its sleek, straightforward design, the compact appliance effectively ... After completing the vacuum sealing cycle, both the motor and the "Sealing" ...Missing: red
Amazon.com: Rival Vacuum Sealer: Kitchen & Dining
Amazon.com, Inc.
Rating: 3.6 - ‎233 reviews
Online Shopping for Kitchen Small Appliances from a great selection of ... Rival FSFGSL0150-015 3 Step Vacuum Sealer w/ Bag Starter Kit ... You push down....wait for Hands-Free light & Sealing light to go on....let go....wait for lights to turn off. ...After a couple of bags were done, I started having an issue in which the unit did ...Missing: red
Amazon.com: FoodSaver FSFRSH0051 FreshSaver ...
Do they make special bags for this unit
They do! You can get them on the Seal-A-Meal website or even on Amazon. Here's a link.
Vacuum Sealers Accessories
Why does my rival seal a meal not seal?
The sealing mechanism is not working properly. Make sure there is no debris in the path of the seal wire - if so the area under that material will not be sealed and there will be leaks.
Seal-a-Meal seal has blister on it
I think that you have the same problem that I have. The protective tape over the heating element [a strip in my case] has a hole in it and allows the element to come in direct contact with the bag. Also, the heating strip had a kink in it was was no longer flat. I carefully cleaned the heating strip and flattened it out as best I can. I have ordered some tape from : http://www.ebay.com/itm/170848027703?item=170848027703&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr to replace the defective one. A simple job.
3helpful
When vacuuming out air, the liquid is vacuumed, inside of the bag where it seals is wet, and it won't seal.
Try placing a folded paper towel in the bag between the item and the area of the seal
The towel will absorb the liquid allowing the bag to seal but keeping the liquid in the bag
2helpful
The small white clip that keeps the nozzle cage dowmn is broken. Can i get it replaced?
Mine broke too.. I contacted Seal-a-meal, and for my machine, they don't make replacement parts anymore. BUT, here's what I did and it works great. I place a chopstick across the length of the lock and seal nozzle...I use a little scotch-tape to hold it in place.. When you shut the lid, it applies enough pressure to the nozzle, to start pulling air out of the bags. I do have to lean or push down hard on the lid, to get it to lock into place, before sealing, but the chopstick works wonderful...I am not going to buy a whole new seal-a-meal when this works so terrific. In fact, I just seal-a-mealed 8 bags of beans this afternoon. Try it before you go out and buy another machine.
2answers
Need to find a heat strip for seal a meal vz110
Model 750 seal a meal will not seal bags
Norm
I own 2 of the vs220 seal-a-meal units one of which worked ok with the bags that came in it and the second is a hit and miss unit. Both were purchased at walmart. I have tried to use the last one that i...
I too bought my seal a meal at Walmart. I have gotten it to work twice. The main problem is it won't seal. I really think it has to do with the black seals....If I pull them up it sometimes will work. It is really frustrating. I would take it back but have mislaid my recept:(
4helpful
3answers
Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Mar 30, 2008 • Vacuums
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
