Question about Tomtom GO 700 GPS Receiver
MY TOM TOM GO 700NOT CHANGE TO REGULAR MODE
HI THERE WHEN I START MY TOM TOM GO 700 JUST SHOW AT THE ESCREEN THE PICTURE OF THE TOM TOM 700 AND I HAVE TO RESET THE UNIT TO TURN IT OFF AFTER THAT I START AGAIN AND THE SAME PROBLEM IS DOING AGAIN
  • Anonymous May 24, 2008
    I have the same problem but it only happened after downloading a few POI
  • ata08 May 24, 2008
Wrong upgrade by the internet call the factory to reset
Posted on Sep 25, 2007
6ya staff
SOURCE:
Won,t switch on,fully charged,where can i find the reset button? Tom Tom (go 4v00.710)Please help
the rest for your go 700 is on the bottom where the mount connects,,see picture below.
Jan 20, 2010 | Tomtom GO 700 GPS Receiver
Change TomTom Go700 from yards to meters
I have a 720 but I suspect it will be the same or similar.
Tap the screen and then Change Preferences. Use the forward arrow to scroll to the relevant page (5 on mine) where you will find Set Units. Tap this and then change whatever units you wish.
Sep 24, 2009 | Tomtom GO 700 GPS Receiver
When turned on, screen has picture of unit with blinking "x" in lower right side and what looks like a "disc" in lower left. will not respond.
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 11, 2009 | Tomtom Go 700 Portable GPS Receiver
Hi, Tom Tom 710 has not come on for weeks.
it doesnt get better by itself. Despite having a green light doesnt mean it is charged. try changing the battery
Jul 05, 2009 | Tomtom GO 700 GPS Receiver
I have a tom tom go 700 which i used only occasionally for the last 4 years England & spain.last weekend i downlouded speed camera data into it except for relative speed information. i turned my sat nav...
after speaking to another owner of a simulal tomtom go 700 iwas told to pres the restore button at the rear of my unit and that solved that problem. kledwood
Apr 08, 2009 | Tomtom GO 700 GPS Receiver
Clearing my tom tom 700 of recent destination and phone numbers
Perform a hard reset. That should delete every last bit of info you have saved on your tomtom. To do this press and hold the power and reset buttons for about 5 seconds.
Regards,
Sai.
Feb 03, 2009 | Tomtom GO 700 GPS Receiver
Tom tom 700 go
hi,
my tom tom 700 go is 4 years old and i don't now how to make
the updates for it please can you help me out
Jul 05, 2008 | Tomtom GO 700 GPS Receiver
Hi my tom tom go 700 dosnt turn on
I had the same issue. I used a paper clip to press the reset button on the bottom of the device.
I hope that works for you. Good Luck
Dec 12, 2007 | Tomtom GO 700 GPS Receiver
Tomtom 700 in a standby mode
Hi Juanin, just posted this for a near identical problem with a Tomtom 700; When you get this kind of problem with a Tomtom device always start with the memory card, so: 1: remove the card, clean the contacts and if you have an air duster (available from any good hardware store/electronics store) clean the card slot, then reinsert it. 2: make sure the card is readable on your PC to ensure it doesn't have a problem. if this doesn't help then 3: format the card and reinstall the maps & software on to it. 4: make sure the card is reinserted correctly. Next is the battery, leave the device switched on until the battery runs out, switch it on again and it should stay on for a moment then switch its self back off, repeat this until it will not switch on anymore and then charge it for at-least 16 hours before trying it again, this will re-calibrate the battery. Diagnosing a problem is a process and this is just the start of it, don't be disheartened if this doesn't help, just message back with the results.
Apr 18, 2007 | Tomtom GO 700 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
156 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
