Watts Onan Portable Generator - 4000 , Model# 5500 Logo
Posted on Apr 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Only runs if I hold the start switch
I have a Onan Emeral 4000 watt generator. It only runs if I hold the start button, when I release it she stops. I have plenty of oil in it and when I disconnect the oil pressure switch and use a Ohm meter on the switch it reads infinity, when I start the generator It goes straight to ground. What else could cause the generator to run only when sthe start switch is held.
  • Anonymous May 11, 2010
    Does the oil pressure switch read infinity when the generator is running?
    To test the oil pressure switch, you could short the lead to the chasis (or if it's two -wire, just connect the two wires together) and see if that solves the symptom.
mamicheddy
Level 2:
Scholar:
  • Expert 79 Answers
  • Posted on May 09, 2009
mamicheddy
Expert
Level 2:
Scholar:
Answers
79
Questions
0
Helped
72879
Points
155
The problem is that you are not creating voltage. Remove front cover. Place a volt meter on the breaker. Start genset and you will see no voltage present. The problem could be with the brushes, rings, rotor, stator, voltage regulator, or control board.
1helpful
Physical location of control board on an Onan 5500
It is right behind the start switch. There is one bolt that holds your start switch housing down, remove it and the housing. You will see the P1 connector with a lot of wires plugged into the control board
Onan 4000 generator
Check the rotor slip rings and brushes first, the rings should be clean and bright
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
I have a onan 6.5 emerald gen,when you start it it quits as soon as you let go of the start button, will run fine while holding start button on,then quits when you release,please help,maybe field not...
More likely the switch is bad, and only make run contact when in the start position.
Easy to test the switch continuity with a ohm meter when it is not running.
1helpful
WHEN I START THE GENERATOR I HAVE TO HOLD THE START SWITCH ON TO KEEP THE GENERATOR RUNING.
The switch should be three positional.
The upper position is only for starting. Continuous running is in the middle (self holding) position. Lower position is to stop the generator.
If left in middle position it is not running you may have the switch bad, or the generator is stopped by low oil level.
Gen starts and runs with rocker start button pushed in..stops....
Cleaning the brushes is used to address an AC output problem. If the generator would run for a few seconds after letting go of the button, then this might apply.
But, since yours is dying as soon as you let go of the button, that tells me that you are probably looking at a low oil condition, or a sensor / sending unit failure for oil level.
Without spec number, hard to remember if the sending unit is for low oil pressure, or low oil level. Either way, the ignition is being grounded. First, double check your oil level, make sure generator is reasonably level. If still not resolved, then locate the sending unit, and remove the wire that is on the end of it. There should be a connector either a few inches from the sending unit, or a few inches from the control board (coming from big white plug). Disconnect at either place. Try starting again. If it starts this time, double check oil levels. If those are fine, then sending unit has failed, or oil pump (if pressure unit) has failed. In either case, don't run for very long until sending unit is replaced, just in case.
3helpful
3answers
RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
6.5KW Onan generator. wont run when the start button is released
Flight systems can test the onan circuit boards. google them they will come up. First class operation my board was was checked out and back to me in about a week, They also sell new boards and deduct the 20 dollar bench fee if yours is bad and you buy a replacement from them.
Top Watts Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
