Acer Aspire 2930-4661 Notebook Logo
Anonymous Posted on Apr 10, 2009
Acer aspire 2930 DVD player only opens some dvds
My dvd player opens some dvds but not others, eg, i can play a brand new version of batman the dark knight but it wont play and brand new version of green street. batman opens up right away and the dvd drive makes the correct noises, but green street doesnt open, it just starts spinning and then stops and starts spinning constantly as if it keeps trying to load it. The dvds are all the correct reigion (region 2). Ive got it set up to open in windows media centre but have also tried the same with windows media player. the dvd drive is called DVD- super multi DL and the laptop is only 1 month old and has never had any damage caused whatsoever. I have windows vista home edition. All other types of cds work like audio, software and games, but just not some dvds. the dvds are in perfect working order and ive tried a brand new one today which wont open.
  • Anonymous Apr 10, 2009
    It can play multi layer dvd as batman is that. Im not very computer literit (and cant spell either lol) could you please explain what i need to do to do what you suggested.
    Many thanks
Nanny
Level 3:
Genius:
  • Acer Master 2,351 Answers
  • Posted on Jan 02, 2020
Nanny
Acer Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988550
Points
7262
If you meet the issue of Windows Media Player won't play DVD, this is because Windows has dropped its support to provide Windows Media Player's built-in DVD codec for Windows 10 and above. You can install dvd codec or try some other DVD player program such as Leawo Blu-ray Player which is free
Anonymous
Level 3:
  • Master 700 Answers
  • Posted on Apr 10, 2009
Anonymous
Master
Level 3:
Answers
700
Questions
Helped
268759
Points
2031
Try Media player classic under k-lite codec pack. Then open video files on the dvd. If it doesn't help try another codec player. If nothing helps could it be that dvd player is not capable of multilayer dvd reading.
2answers
Acer aspire 5349 wont play dvds only cd
Try installing a new software program to play your DVDs. Also look for updated dvd player drivers from Acer site.
Hi,MY ACER 4720 Dont play any DVD but playing cd /copying CD is fine.When i checked its property,Driver shows as CD ROM driver.i did not find any dvd driver.Could anyone help
The DVD player may be set to a Region that does not match the Region code on the DVDs.
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware that allows you to play DVDs from any region. There are severalavailable on the Internet but my favourite is DVD-Region Free From: -
www.dvdidle.com/dvd-region-free.htm
1helpful
2answers
My Acer Aspire 5735z has no sound on dvds in Real
use the driver cd which came along with your laptop and reinstall the audio driver from it. After that reinstall the real player as well if needed.
After that everything should work fine.
I hope this is helpful to you.
Thanks
1helpful
2answers
DVDs play with no audio
Nothing went wrong but it require audio codecs to be installed your DVD drive must be having a CD with it which has nero burning softwares and other like nero show time and dvd codecs. Install this programe from the cd supplied with it. use power DVD etc. many softwares are there .dvd play back
Exteral DVD 1 from India & 1 from the USA neither paly DVDs
What region is your DVD player locked on and what region DVD disc are you tyying to play?
Got acer aspire notebook with combodrive.it plays all dvds except all ntsc hindi songs dvd.it does not even recognize a dvd in drive.
if you want to play any of the thousands of DVDs imported from any of the other FOUR REGIONS? You need to make your DVD player (or your Windows PC or Mac) REGION FREE, try download region-free software to unlock your DVD player, and make it can play ntsc hindi songs.
1helpful
2answers
Brand new acer,spindle is too large on multi drive for cds or dvds
There are three little spring loaded things that you have to push together to get the DVD or CD to fit, I had the same problem
Laptop will not play dvd
You need a program like WinDVD to play DVD movies. You can download a trial version here.
Thanks and please take a moment to rate as fixya. Thank you.
2answers
Compaq DVD Player problem
You need a new DVD codec. If you have a copy of WinDVD, give it an install. Otherwise, try the free codec on www.divx.com.
Drive can't read DVD
Jeff - If you have not changed your software configuration in any way since the last time you could successfully play a DVD, it could be that the drive has failed. You can test this most easily by taking these DVD's that won't play in your Acer now, and play them in another good computer, or a regular home DVD player. If they play in your other systems/players, you will see right away. And if the machine is that new, you might be able to get it easily fixed under your manfuacturer's warranty.
If you have made any kind of changes to your system software that could affect your dvd burner, that could cause it to not recognize them perhaps, as well. By changes I mean - installing some kind of alternative dvd playing software than what came with your machine, etc. If you did not make any software changes, it is likely a hardware problem.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
