I have a finlux 42" 3d tv and my pc is connected via hdmi cable, the picture is there but i can not get anything else on there such as start bar and other icons. how can i fix this please?
What type of video card does your pc have??? if it is an nvidia card, you have to go to the control panel and set up for dual monitor..when you connect your laptop to an external monitor, you have to press control and f8 keys for couple of times ...that adjust the color to 256. Are you doing that?
No I'm afraid not. It only supports VGA out. If your TV supports a PC input then a male to male VGA cable will do. VGA does not support audio so you will also need an audio lead to connect to the TV too.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp. To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: - www.ladparts.net
I think your set of wires (A.V cords) may be faulty try riggling them in the plug -you may have to buy new set(they are reasonably cheap) otherwise make the people you bought it off get you another set
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day. is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
