Perform a Factory Data Reset of Acer ICONIA
The
following steps will erase all of your personal information, all stored
contacts and any programs you have installed on your tablet.1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With
the Volume up button held, press and hold the Power button for 3
seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release
the Volume up button and stop switching the touch screen lock switch
once the "Erasing Userdata..." message appears in the upper left corner
of the screen.
6.Once the factory reset has been completed your
tablet will load to the Welcome screen. 7.Your Factory Data Reset has
completed now follow the onscreen steps to setup your tablet.
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
