Question about Microsoft Office Excel 2003 for PC
Can I provide password for a hyperlinked spreadsheet
When a User click a Hyperlink to open a linked spreadsheet , password needs to be asked so that only authorised person can open the spreadsheet
  • nilayumalkar Apr 10, 2009
    no, it is not file but one sheet has hyperlinks for remaining sheets of same Excel File, seleceted user should be able to open selecetd sheets only through hyperlink
  • 29 Answers
Save the file to the desired location & then right click on the same & set the password. If you know the password then only the file would open
Posted on Apr 10, 2009
6ya staff
SOURCE:
I am trying to copy text from Word that has a hyperlink into an excel 2010 spreadsheet. how do I make hyperlink work in excel?
This is what the HELP feature is for in the top toolbar :>)
  1. Right-click the text or graphic you want to represent the hyperlink, and then click Hyperlink on the shortcut menu.
  2. Under Link to on the left side of the dialog box, click Existing File or Web page.
  3. Do one of the following:
    • To select a file from the current folder, click Current Folder and then click the file you want to link to.
    • To select the Web page from a list of browsed pages, click Browsed Pages and then click the Web page you want to link to.
    • To select a file from a list of files you have recently used, click Recent Files and then click the file you want to link to.
    • If you know the name and location of the file or Web page you want to link to, you can type that information in the Address box.
    • To select the Web page by opening your browser and searching for the page, click Browse the Web 1922.gif, open the Web page you want to link to, and then switch back to Microsoft Excel without closing your browser.
  4. To assign a tip to be displayed when you rest the pointer on the hyperlink, click ScreenTip and then type the text you want in the ScreenTip text box. Click OK.
May 06, 2016 | Microsoft Excel 2010
Tip
Script to extract URLs in Excel Spreadsheets
The following script could be used to extract the actual URLs from the text link in an Excel spreadsheet. The script writes each URL in the cell next to the text link:
Sub main()
Dim h As Hyperlink
For Each h In ActiveSheet.Hyperlinks
h.Range.Offset(, 1) = h.Address
Next
End Sub
Here is how to use the script:
1. On the "Tools" menu, point to "Macro", and then click "Visual Basic Editor". This will open the Visual Basic Editor in another window.
2. On the extreme left, you will find the "Project - VBAProject". Double-click the icon named "Sheet1 (Sheet1)", "Sheet2 (Sheet2)", or whatever the name of your worksheet. This will open a blank window. Copy & paste the script into this window.
3. Press F5, then click on "Run".
4. Go back to your Excel window. You will now find the URLs listed in the next cell to the original one with the hyperlink.
on Dec 01, 2009 | Microsoft Excel for PC
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
Feb 21, 2014 | Microsoft Excel for PC
Need to put password on next solution router
Connect the router and computer to create a secure connection between the two pieces of equipment.
To do this, plug an Ethernet cable into one of the LAN (Local Area Network) ports located on the back of the Belkin router.
Connect the other end of the cable into the Ethernet port located on the back of the computer (the side of the computer, if you are using a laptop).
Access the GUI (graphic user interface) to gain access to the router settings.
To do so, open a web browser and enter 192.168.2.1 into the address bar of the browser.
Press "Enter" or "Return" on the keyboard.
Click on the "Login" hyperlink located at the top of the page. Enter "Admin" into the username and leave the password blank.
Click "Submit" to load the GUI.
Click on the "Security" hyperlink located under "Wireless."
Select "64Bit WEP" or "128Bit WEP" from the drop-down menu and enter in any 10-digit hexadecimal password into the "Key1" box.
Hexadecimal is a password with both letters and numbers in it.
Select "Apply Settings" to update the router's security password.
Use this password to connect your computer and on other equipment to the router.
Nov 11, 2013 | Belkin My Essential (ME1004-R) Wireless...
Can I attach a link to a Word document within a PowerPoint 2002 presentation?
Yes, You can make it hyperlink. You just need to right click on the document where you want to add link and from the option select "hyperlink". Then it ask you the document location. Select the document and click on Ok.
Aug 23, 2009 | Computers & Internet
HOW TO HYPERLINK THE FORMULAS IN PRESENT SHEET1 OF
1. You can do it by-inserting a hyperlink and from the "insert hyperlink" window, select "place in this document" from the "Link to" pane. Then you can select desired destination sheet
2. First from unlock all cells from the format-protection menu.
then lock only those cells which you want to restrict access to the users.
then if you are using Office 2007, from the "review" tab select "protect sheet" then uncheck "Select locked cells" check box.
click ok then you are done.
Aug 11, 2009 | Microsoft Excel for PC
Excel 2000 Issue???
.Let's start with this for more info:
Is the URL icon there but blank? (Maybe an X in the middle of the box?) If it's there, do the following:
Right-click on the URL
2. Select Hyperlink from the menu that appears
3. Is Remove Hyperlink box checked or unchecked?
This is a setting that is machine-specific. Post the answer as a comment and we'll take the next step if necessary
Apr 02, 2009 | Microsoft Office 2000 Professional for PC
When a hyperlink is in my email (Outlook Express) I can't open it
Clicking on links in eMail is the fastest known way in the Universe to have your all on-line log-ins & passwords stolen ...
So more than one mail viewer now has the ability to block this action ... I expect you will find the control in Security / Advanced settings ... however (I would suggest) on this occasion, the PC really does know better :-)
Mar 12, 2009 | Dell Inspiron 5100 Laptop
Hyperlink function in ms access
To Create a Hyperlink Field:
Display the table in Design view, create a new field to store the hyperlinks, click the new hyperlink field's Data Type box, click the list arrow, select Hyperlink, and save the table.
To Insert a Hyperlink:
Select the hyperlink field and then click the Insert Hyperlink button on the toolbar or select Insert , Hyperlink from the menu. Either select a file you want (use the Browse button to help you locate the file) or type a Web address for the hyperlink's destination and click OK.
To edit a Hyperlink: Right-click the hyperlink and select Hyperlink , Edit Hyperlink from the shortcut menu.
Is this enough?
Dec 21, 2007 | Microsoft Office Access 2003 (077-02871)...
Microsoft Office Excel 2003 for PC Logo
89 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
