Question about Canon PIXMA MP830 All-In-One InkJet Printer
Printer is putting a 1/2 dark black line on the back of the pages
When I print pages, there is a 1/2 inch black line from top to bottom on the back of the page about 1/3 of the way across from the side edge of the paper - there appears to be black ink on rollers ejecting the paper?
  • 1 more comment
  • mbtcs Apr 10, 2009
    i have always used canon cartridges, i found another post that mentioned cleaning the ink pads? i am going to call the printer repair shop in the morning to see what they would recommend.
    thanks!
  • YorksRick Apr 24, 2009
    I have exactly the same problem with my MP830. I only use original Canon cartridges. Have tried endlessly cleaning the roller and bottom plate. Have also tried replacing the black cartidges, but no improvement.
    There is no obvious sign of ink leakage.The place where the cartridge sits is completely dry when you take it out.
  • bev924 Apr 27, 2009
    I recently started to have this problem with the black ink streak down the entire center of the back of the page but only with 8 x 10 so far. I also tried cleaning the rollers and the platen with no change. I'm wasting a lot of paper and probably black toner also.
  • 59 Answers
Dear friend
looks like problem related with refilled cartridges
are you using refilled cartridges??
if yes then you have to check whether they are leaking or not,
if they are leaking, you have to maintain cleaning level
thats all you can do
thanks
Posted on Apr 10, 2009
6ya staff
SOURCE:
Printer prints off left side of page
You're Registration is off. This is an adjustment that must be done in the Diagnostic mode of the printer. You're better off getting an actual tech who knows how to make this adjustment. You can move the image left/right and top/bottom. Can mess things up bad if you don't know what you're doing.
Mar 11, 2017 | Lexmark Look E332n Laser Printer Look
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
On left hand side of page horizontal line
You might have touched the main charger cleaner a green part above the waste toner container. just push it inside and try to copy and print
May 11, 2010 | Copystar Office Equipment & Supplies
Black Vertical Line on the paper
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine;quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. if the issue is there at that point then it would point to the cartridge. if not then the fuser
Let me know....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2009 | Brother HL 5140 Laser Printer
Printer is Not using all the colors when printing?
if you download the ssc you can do a power clean if you dont have this tool let me no
Nov 16, 2008 | Epson Stylus CX9400 Photo Printer
Hp laserjet 4250
try this
1.when the printer start print turn off the printer after the paper go on side the printer to make paper jam
2.open the printer and pickup the paper out slowly
3.see the print area on the paper if the black par appears on the paper that mean the drum unit faulty if not the fusser unit faulty
May 14, 2008 | HP LaserJet 4250n Printer
Lines along edge of paper
1 of 3 things I can think of off top of my head.
Since they are straight, I would suspect the transfer unit.
If it were just one color it would be that imaging unit.
Unlikely the fuser.
It doesn't sound line an issue called bar coding ,where the machine prints random lines. That would be a software issue.
Take the transfer unit out and inspect it for the marks.
I am assuming the streaks are on all colors correct?
If it isn't on the transfer belt, and on all colors check the fuser and see if its latched.
Jan 16, 2008 | Xerox Phaser 7400DN Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
313 people viewed this question
Clive
Clive
old marine
old marine
Ekse
