Model: HWM-2000, Honeywell Natural Warm Moisture Humidifier (2-gal)
The humidifier is POWERED, the water tank is FILLED, the humidifier control is turned to MAX, the humidstat is turned to HIGHEST SETTING, and the humidity light is OFF (meaning the unit should be producing moisture).
I can hear the humidifier engine is ON, but I can see/feel NO moisture / vapor coming out. This has been been for a few hours already. Could the humidifier be defective (this is fairly new), or is it not getting the water feed properly?
Anyone suggestion on how to solve / debug / fix this would be appreciated!
Warm moisture humidifier Model HWM-2000
I have used the humidifier for 3 years an just noticed this problem
Check the thermo protector fuse at the bottom near the heating pad. The fuse must not be open circuit. If it is, replace it. You can order the fuse for $1 from eBay or Amazon. Good luck!
