The manual for your computer is available from
emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in
magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (
pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
opps wrong key
question is it a 10 pin header with with 1 pin short of the 10
can you give the emachine model #
the # given is motherboard made by Imperial_GV 20030812
can you take a picture of MB near the corner where cmos battery is
question is
