Hi I've got a logik twin screen DVD player for the car but the cable that links the screens seems to be faulty? The second screen turns on and shows the blue Av screen but no picture of the DVD if that makes sense Can I buy this cable? It has 2 plugs on, one goes into the DC for battery the other into AV
SOURCE: INeed av cable for Trutech 7? Dual-Screen Portable DVD Player
Okay, I just had to replace both the DC power and a/v cable for this Trutech DVD player and here is the solution. The a/v cable is a 4 pole 3.5mm cable, which I found here: http://www.techcables.com/6-ft-3-5mm-4-pole-mini-av-to-mini-av-camcorder-a-v-cable-p-36.html I went to Radio Shack and bought the coax style DC power plug ends which were size B and soldered new ends onto the old power cable, tip to tip, sleeve to sleeve: http://www.radioshack.com/product/index.jsp?productId=2102598
SOURCE: I have a trutech LMD5702RT portable duel screen
If its the red white and blue AV cable on both ends yes you can. If its a red white and blue AV on one end and a audio looking jack on the other end you can too. They sell all those cords at Radio shack or most electronic stores.
SOURCE: Need new car charger adapter and cords for Coby Twin DVD Players
i need tis car charger adpter and relating cords to my twin coby dvd players replace how to do htis; where to buy im in jacksonville florida .thank you
SOURCE: I've been using AV cables
Configure the player to output Y/Pb/Pr to the TV. Make sure it's not configured to S-Video or anything else.
Venturer PVS7287 Twin Mobile DVD Player 8" LDC Screens - I was getting a blue screen with the DVD not loading. I could see the ribbon cable was just slightly off from the side of the optic eye board. I gently pushed it back on with the tip of a screwdriver. I didn't have to take the player apart, as you you can see the optic eye and the cable that attaches to it when the door is open and the DVD removed. Be careful with the ribbon cable, it is very thin.
