I have a Belkin G 54 Wireles rooter and a Belkin rang extender. The range extender keeps losing the signle and I have to keep reseting it. Can you help me .
Using the reset button
The location of your range extender's reset button will vary depending on its model. The reset begins once you press and hold thereset button for at least10 seconds while the range extender is powered ON. The Status Light on the the range extender will momentarily flash and will then begin to blink. When the light becomes solid again, the reset is complete. Using the web-based setup page
If using the physical button does not work, you can access the range extender's web-based setup page and do the reset from there.
Before you begin:
Make sure that the wireless computer or device you're using to access the web-based setup page is connected to the same network as the range extender.
You need to identify the IP address that your router has assigned to your range extender. Locate this by accessing your router's DHCP Client table. Once you have the range extender's assigned IP address, use it to access your range extender's web-based setup page.
Alternatively, you can enter "http://192.168.206.1" in the web browser's Address bar if your range extender has NOT detected a DHCP server in your network.
Step 1:
In the web-based setup page of the range extender, go to Utilities and select Restore Factory Defaults.
QUICK TIP: You may be prompted to log in with your range extender's administrator password. If you have not set any, simply leave the field blank and click on Submit.
Step 2:
Click on the Restore Factory Defaults button.
Your Belkin range extender should now be restored to its factory default settings.
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
