D-Link DP 300U (DP-300U) Print Server Logo
Anonymous Posted on Apr 09, 2009
Dns server prob
I try to connect my d-link to my xbox but i do not know what the dns or the primary and secondary ip or my gateway is
Anonymous
Level 3:
  • Master 741 Answers
  • Posted on Apr 09, 2009
Anonymous
Master
Level 3:
Answers
741
Questions
Helped
287657
Points
2256
Click on start>run>cmd. Then type in ipconfig /all. That will give you the IP address to your gateway and any other address you need.
Please rate this solution.
Connetion error 80130128
1. on pc, run -> cmd
2. ipconfig
3. Read the "gateway" ip. Put that into browser to go to router's admin page
4. Find the DHCP settings for router to see what range of IPs it hands out; pick one outside that range
5. Set up the ps3 with that IP, the router IP as primary dns, and an opendns server as secondary This made the connection test happy. But when he tried to go to the playstation store, it gave a DNS error. If he repeated the connection test again, it failed too. "Well," I told him, "It's supposed to try both DNS servers. But we can try setting the primary DNS server to opendns as well." Once he did that, everything worked. (In case you don't know, Run is on the Start menu, usually on the right-hand panel.)If you try that, it might well be possible that your problem is solved. If this doesn't work for you, please call our Network Call Center
Hey im tring to connect to xbox live through hughes net but i need my primary dns server and my secondary dns server and some other stuff and i was wondering if u could help me please
I'm not sure why you would need that. If your connecting your xbox through a router, it should get an address automatically, however you can always try some free public dns servers, such as googles
The Google Public DNS IP addresses are as follows:
  • 8.8.8.8
  • 8.8.4.4
Connection to winows media failed
1. check your netwok calble properly
2. check your router internet connection
3. follow these steps
Accessing network settings loadTOCNode(2, 'moreinformation'); To access the Network Settings area, follow the steps for the version of the Xbox 360 Dashboard that you are using.
New Xbox Experience Dashboard:
  1. From the Xbox 360 Dashboard, select System Settings in the My Xbox area.
  2. Select Network Settings.
  3. Select Configure Network.
Legacy Xbox 360 Dashboard:
  1. From the Xbox 360 Dashboard, move to the System blade.
  3. Select Edit Settings.
IP settings, IP address, subnet mask, and gateway loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this imagenetworksettings-basic.jpg
After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the IP Settings block, you are prompted to select an Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your IP settings from your network or from your modem or Internet service provider (ISP). This option is recommended for most users.
You may have to or prefer to manually configure the IP settings, especially when a static IP address is used. This is necessary only if your ISP has issued a static IP address, or if you have configured the router to issue static IPs (and DHCP is not used). To manually configure the settings, select Manual, and then enter the IP Address, Subnet Mask, and Gateway by using the keyboard on the screen. When the information is complete, select Done.
DNS settings, primary and secondary DNS servers loadTOCNode(2, 'moreinformation'); After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the DNS Settings block, you are prompted to select Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your DNS settings from your network or from your modem or ISP. This option is recommended for most users.
You may have to or prefer to manually configure the DNS settings, especially in scenarios in which a static IP address is used or where DHCP is not available or not offered by the ISP. To manually configure the settings, select Manual, and then enter the primary and secondary DNS server names by using the keyboard on the screen. When the information is complete, select Done. Note You do not have to enter a secondary DNS server to connect to Xbox LIVE. A secondary DNS server is required only if the primary DNS server has technical problems.
Wireless settings loadTOCNode(2, 'moreinformation'); To configure your Xbox 360 console to connect to your wireless network by using an Xbox 360 Wireless Adapter, follow these steps:
  1. Access Network Settings .
  2. On the Basic Settings tab, select Wireless Settings.
    Note If the wireless settings area does not appear or is unavailable, click the following article number to view the article in the Microsoft Knowledge Base: 909333 (http://support.microsoft.com/kb/909333/ ) While attempting to view the settings for a wireless network connection, all the wireless functions appear to be disabled in the Xbox Dashboard
  3. Follow the instructions to select your wireless network, select your wireless network name, and then enter your wireless security information.
  4. Select Done.
PPPoE settings loadTOCNode(2, 'moreinformation'); If your Internet service provider uses PPPoE authentication, you have to enter the settings in the Xbox Dashboard if you have a direct connection through a modem. If you use a router or a gateway instead, leave the PPPoE settings blank because the router performs PPPoE authentication. Note If your ISP does not use PPPoE authentication, make sure that these settings are blank. To learn whether your ISP uses PPPoE authentication and to learn the correct PPPoE information, contact your ISP.To configure the PPPoE settings on your Xbox 360 console, follow the steps for the version of the Xbox Dashboard that you are using.
New Xbox Experience (NXE) Dashboard:
  1. Move to the System area of the Xbox Dashboard by using one of these methods:
    • Press the Xbox Guide button on your controller to open the Xbox Guide, scroll to the right to access Settings, and then select System Settings from the list of options.
    • Select the My Xbox channel, and then scroll to the right to select System Settings.
  4. On the Additional Settings tab, select PPPoE Settings.
  5. Use the keyboard on the screen to enter the PPPoE information that was provided by your ISP.
  6. Select Done.
  7. Select Back to return to the main Network Settings area.
  8. Select Test Xbox LIVE Connection to restart the test with the new PPPoE settings that you have configured.
sure it will work thank you
2answers
How do i set up xbox live
  4. Select Done.
  6. Select Done.
1helpful
I AM SIGNING UP 4 XBOX LIVE AND MY INTERNET CONNECTION FAILED IN RESULT OF AN INCORRECT SECONDARY DNS SERVER IM WONDERING WHERE DO U GO 2 FIND THAT
Have you tried dns settings in automatic? I take it from your post that you have the primary dns server, my primary and my secondary has only one number difference,
primary 194.168.4.100
secondary 194.168.8.100
you only have 9 numbers to try so its worth a go, I hope this helps because I know from experience what a frustrating pain in arse this can be.
Remember thumbs up if this helps.
Unable to connect to xbox live mssg says strict NAT Type . ALready disconnected and restarted everything more than once
Alright Try hese steps:
1 - Assign a Static IP address in the Xbox:
- Go To Network Settings - Configure Network
- Change IP settings to Manual
- IP Address: 192.168.2.45 Subnet Mask: 255.255.255.0 Gateway: 192.168.2.1
- DNS settings to Manual
- Primary DNS: 192.168.2.1 Secondary DNS: 4.2.2.2
2 - with any of the Wired Computers
- open IE - type - 192.168.2.1 - u'll get the Router Interface
- left hand side in the list of options
- click Firewall - leave password blank - disable and apply changes
- click Virtual Servers;
- under enable place a checkmark
- description : Xbox, Inbound Pot : 80(if there are two boxes here duplicate in both the boxes), Type: TCP, Private IP: 45, Private Port: 80
- So Similarly fill up the table for these following Ports
TCP: 80, UDP: 88 Both(TCP&UDP): 53, 3074
Additional Note:
If u've a DSL connection, call ur ISP and make sure ur modem is bridged and the NAT is disabled
How to use network inventory ? what is it requirment ?
Installed Windows server 2000/2003/2008 on server PC
Set IP address as 192.168.0.1
     Subnet address : 255.255.255.0
     Gateway :  Blank (only if you use router)
      Primary DNS  : 192.168.0.1
      Secondary DNS : Blank
Set up the server as Domain Controller plus DNS server.Here is the link on how to
1) http://www.visualwin.com/AD-Controller/
2)http://www.ssw.com.au/SSW/Standards/DeveloperInstallationNetworkSetup/Windows2003_01DomainControllerSetup-InstallingActiveDirectoryandDNS.doc
Client setting
Set IP address as 192.168.0.2
Here is the link on how to join the domain
1) http://www.petri.co.il/joining_a_domain_in_windows_xp_pro.htm
2) http://www.windowsnetworking.com/articles_tutorials/wxpjoind.html
Client Operating system must be windows xp pro,2000 professional,Vista ultimate etc
Cant connect to my xbox live
Alright Try these steps:
Additional Note:
My xbox 360 says its connected to the internet, but it wont sign in on xbox live
To troubleshoot your Xbox Live connection from the Xbox Dashboard:
  1. Go to the System area of the Xbox Dashboard.
  3. Select Test Xbox Live Connection.
  4. After the system has completed its tests, select More Info to learn more about your network, paying close attention to any test that failed.
    In each case, the More Info section will offer tips for correcting the conditions preventing you from accessing Xbox Live.
  5. Select Edit Settings to adjust your:
    • IP Settings (including IP address, subnet mask, and gateway)
    • DNS Settings (including primary and secondary DNS servers)
    • PPPoE Settings (including user name, password, and service name)
    • Advanced Settings (including host name and altern
2helpful
Xbox DNS server
Go to start->run on your computer, and type "cmd"
When the command prompt comes up, type "ipconfig /all", this will list all of the information about your IP address. Find the DNS Servers option, and copy that onto your xbox.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
