Question about Boating
SOURCE: Searay 270 SLX wont turn over
were the batteries stored outside in winter ? if so check to see if there is any bulging on the sides... they may have froze which will require replacement .... either way do you have a method to check the voltage under load (starting) as that will show you the try condition of the batteries
Posted on Mar 13, 2009
SOURCE: I have a 150 hp outboard Mercury that is
Part of the problem was apparently of my own making. Number one, have to remember to check the safety switch located right below the throttle area. The toggle was kicked to the OFF position. May have hit it while wiping down the console in preperation for taking to the water. Once I found the problem, still had an issue with getting gas to the carbs. I pulled the quick connect of the primer system off where it connects to the engine and had to bleed multiple times to get air out and could see gas coming through the glass filter cleanly. Boat started on the second time over. Just like always did for me. Took to lake and runs fine now.
Posted on May 18, 2009
SOURCE: Boat motor won't turn off !
im not sure on your motor but if you have a choke tube with a cylinder in it the cylinder could have came out take the top off and hit your choke and see what moves
Posted on May 25, 2009
SOURCE: have 1975 Merc 115 h.p. motor. won't turn over with key
it may be your neutral safety switch. Try it again but this time turn the key with one hand and wiggle the throttle/shifter lever at the same time. My 25 johnson does this, but usually I can wiggle the shifter and she'll turn over. Hope this helps.
Posted on Jun 23, 2009
SOURCE: I am replacing an ignition switch in a boat. I
cant send wiring diagram -too big for this site-did try-and have one for mercury in line series
Posted on Nov 04, 2009
Jul 17, 2016 | Boating
Jan 03, 2014 | Cars & Trucks
Dec 28, 2013 | 1994 Toyota Camry
Feb 16, 2018 | 2006 Ford Taurus
Apr 19, 2013 | 2001 Mercury Sable
Sep 21, 2009 | 1999 Toyota Camry
Sep 20, 2017 | 2003 Jeep Liberty
Jul 21, 2009 | Light Outboard Motor Boat Bass Fishing...
Jun 23, 2009 | Light Outboard Motor Boat Bass Fishing...
Nov 21, 2008 | Chevrolet Blazer Cars & Trucks
Nov 09, 2019 | Johnson Boating
51 people viewed this question
